Is it still possible to get the "Spiral pin with compression spring" part number 34406751588 as an individual item or do i have to buy the whole spring repair kit #34419064266
Regards
Iain
Handbrake parts
C33
E30Mark
From my experience the spring repair kit (Spiral pin) doesn't fit / work on a E30! I even asked our local dealer how they were supposed to fit, and there technicians said they didn't know
If your original back plate is OK then hopefully Cotswold can supply you with just the original spiral pin 34406751588
PM for details
PM for details
C33
Cheers, I'll wait to hear from them, I was investigating some rear axle noise, took the disc off and found one of the pins bent 90deg and a bit ground off sitting in the bottom of the drum. :S Everything else seems ok though.
Regards
Iain
Regards
Iain
Cotswoldbmw
Hi Iain
if you want the pin then they are still avalible at £0.75 each
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
