Do i need a particular adapter? have a pioneer HU i want to put in but not sure what i need! do i need an aerial adapter as well?
cheers
What do i need to fit an aftermarket HU?
Morat
You generally won't know until you take out the existing head unit, most E30s have had their wiring hacked about by now.
Junglistjed
Is there a certain adapter i will need if everything is standard?
Probably; I think the standard E30 looms were designed for 1980s Blaupunkt head units.
trevski
You will prob need to hack it.Junglistjed wrote:Is there a certain adapter i will need if everything is standard?
Junglistjed
the cassette player just pulls right out, if i remove the cage, will an aftermarket HU fit correctly? or will i need something to help it fit (like a fascia)
trevski
Get an after market head unit that has its own cage then just swap them
Junglistjed
Already have an expensive HU that i want to put in, no cage
also need to know what sort of wiring loom i will need and if i need an aerial adapter!
