dips and glens 750 converstion questions
treeseries
does anybody know, obviously some1 does what gearbox they used to do the 5litre converstion it says manual box but i thought they came with auto boxs, i read the whole thread and cant find what box it was im gonna do this swap myself and was interested.
think they are 6 speed manuals from the likes of 850csi. A very expensive bit of kit, i mean like £1K-£2K for a box
e21Jason
Hi
It was a rare and V expensive 850csi box
Jason
Jason
treeseries
does any1 know of any other boxs that mite fit etc
glenn
- Engine Transplant Services
we used a 6 speed box out of a 850csi
dips346
- London Meets Main Man
as said above 6 speed from a 650csi ,not cheap and not easy to come by .
i dont think anythink else works ,you could always buy my car
Yaninnya
No, only S6S 560G gearbox from 850i (manual - rare) and 850CSi (even more rare).treeseries wrote:any other boxs that mite fit etc
Jan
treeseries
how much is your car likely to set me back dips?
crazymonk
I don't know if the 6 speed box from an E36 on M3 Evo would fit? they are geared to take a similar power to the V12, but I don't know if they fit the V12 engine?
S50 box is never going to fit, it would probably be cheaper to have a piece of auto box bell housing tigged onto an S50 box than find one from an 850
treeseries
i dont suppose i could grab a list of parts off you could i? or glen if you wouldnt mind writing out the idiots guide to v12 swaps that would be a great help
glenn
if i had to write out a guide, then it would be like re-writing the original thread.treeseries wrote:i dont suppose i could grab a list of parts off you could i? or glen if you wouldnt mind writing out the idiots guide to v12 swaps that would be a great help
it might be easier if you made a start on your conversion and give me a shout if you get stuck on something and i'll do my best to help.
dips346
as glenn said ,but dont take this conversion likly as you will need a fair but of money to do it right plus the main thing of a gearbox , 99% sure you wont get a auto box in they as the engine will not sit in the right place at all
benjy
Ive got the removable bellhousing from a 750 auto box, if its of any use to you......
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
treeseries
thanks every1 for your comments i know its gonna be a challenge i think ive found the box though so im ok there. its not a project i plan to rush as the car its goin in is an on goin project with me so dont expect to see it any time soon. but i'll do my best and keep in touch.
jkarran
Have a look on www.locostbuilders.co.uk and search for 'bellhousing', 'gearbox adaptor' and the like, loads of simple innovative ideas on there along with tips on getting alignment right. First thing I'd consider after not finding an E31 box is welding the bolt ring (cut down) from a 750 autobox onto a cut down manual from something with a similar power output (M3, M5, Supra, T5 etc). Either that or make an adaptor plate.
What flywheel and clutch have others used? Can you still buy a new flywheel and ring-gear?
jk
jk
E30 320i Rally Turd - Usually broken
E24 635Csi - Rotting in peace for now
E34 540i - Daily driver
Blown R1 Striker - In progress
- **BANNED**
There was a bit in the Alfa V6 thread about making a bellhousing.Not something for the fainthearted,mind,a V12 into an E30 is much like that....
Youth is wasted on the young.
chu346
Toby_Unna
- Boost Junkie
some useful info there Chu
lambo replicas though
jkarran
Pity none of those make clear how they dealt with the clutch, the best of the fake lambo motors still has the flexplate fitted in all the pics. Custom flywheel and clutch would cost more than the motor, wonder if any other stock flywheel will fit
jk
jk
