M50 non Vanos ??
m-dtech
Unapproved Trader caution
Post Sat Dec 16, 2006 5:18 pm
I have the chance of an 1992 M50 engine from an E34
Is this the non-vanos one ?
M
irish320i
Post Sat Dec 16, 2006 5:27 pm
probaly a single vanos engine i think
kam-325i
Post Sat Dec 16, 2006 5:33 pm
the M50TU is the one with Vanos.
eko
Old timer
Post Sat Dec 16, 2006 5:35 pm
Could be nonvanos?
The M50 in my car came from a 92 and is non vanos,also got another 92 E34 here which is non vanos!
jmc330i
Post Sat Dec 16, 2006 6:14 pm
I think the Vanos engines (TU) are from 93 on, so its most likely a non Vanos.
James
'91 325i Sport
'93 318i touring 16v
Post Sat Dec 16, 2006 6:58 pm
Ive got a 92 525 and its non vanos
Jimbob
Post Sun Dec 17, 2006 11:56 am
Is Vanos an added issue when putting it in an E30 opposed to a non-Vanos unit? (regardless of faults!)
Post Sun Dec 17, 2006 11:58 am
Jimbob wrote:Is Vanos an added issue when putting it in an E30 opposed to a non-Vanos unit? (regardless of faults!)
No difference at all as regards fitting it - but it makes a real difference to the performance!
Jimbob
Post Sun Dec 17, 2006 12:24 pm
Really!
There's a cheap 5 series on ebay at the mo with FSH, but it's a 1994 so I guess that's a vanos unit.
Just went round to nextdoor and they known a bloke with a J-plate with a blown autobox, they're not sure if it's M50 or not though.
Jimbob
Post Sun Dec 17, 2006 12:58 pm
Another quick question Brian, what flywheel/gearbox/prop/diff combination are you using?
I've read that with about 7mm off the M20 flywheel will allow it to fit to the newer 2.5 block, I'm guessing the same goes for the 2.8 block? Then it would just be a case of finding a 3.64 LSD or similar.
Post Sun Dec 17, 2006 1:25 pm
Jimbob wrote:Another quick question Brian, what flywheel/gearbox/prop/diff combination are you using?
Diff is ex. 525e. (Got the 2.7 bottom end as well, for a future project)
Flywheel and gearbox are from a non vanos E36 320 that was lying around, and prop is a standard E30 325 one, just about closed up as far as it will go.
m-dtech
Post Sun Dec 17, 2006 3:44 pm
vanos unit presents a problem when turbo charging and using megasquirt.
