Has this conversion been done.
Putting a S54 E46 M3 engine into a E30 ?
If so could somebody be so kind as to point me in the direction of the details.
Ive done a search, but throws up SO many unrelated options it takes ages to sort through....
Ide like to maybee do this.
Thanks.
E46 M3 engine into a E30.??
Nine468
Dave W.
topbananabm
yes it has been done into E30 m3 clive sanchez of munich motors (PBMW october issue 2009)
Cook318IS
"glenn" on here has also done the swap. Have a search on here under his username and im sure there will be a few details on it
jaistanley
There are a few ways to do it...
1. Run the std E46 engine loom.. This is the most difficult as it requires huge amounts of un-picking looms, hiding away E46 electronics in the E30 and fooling the ECU into working.
2. Run S50B32 engine loom, ecu and management. This has been done a couple of times with a few tweaks here and there. Good results apparently.
3. Run an aftermarket ECU on a modified engine loom. You can buy and off the shelf kit, pre-mapped. You supply an exchange loom which has a surcharge..
Otherwise, you get the engine in the same way you do an S50. New oil pump, M50 (E34) sump and oil pick up, E36 M50/S50 engine mount arms, E28 M5 engine mount rubbers, E36 M3 radiator etc etc..
hope this helps.
Jai
hope this helps.
Jai
Steve
webmaster@e30zone.net
