few turbo questions
stembo21
Post Tue May 05, 2009 5:38 pm
right am getting a e30 325i and am thinking about turboing it.
what is the standard compressing ratio on a 325i
and what power does a standard internals take and wot is the best compression ratio for a turbo and also what ecu can i use i was told you can use standard ecu is this true
maxfield
Post Tue May 05, 2009 5:48 pm
Early 325i's are 9.5:1.. or about that.
Later 325i's are 8.8:1.
Not sure about what standard internals will take.
I wouldn't use standard ECU as the fueling/ignition will never be spot on. Go for a standalone ECU. A lot of people use MegaSquirt.
blingsta
Boost Junkie
Post Tue May 05, 2009 6:06 pm
Standard internals should be good for 350bhp
stembo21
Post Tue May 05, 2009 6:20 pm
blingsta wrote:Standard internals should be good for 350bhp
thats good for me i want about 270bhp wot will i need to do that?
a list would be grate
baptie0
Post Tue May 05, 2009 7:43 pm
turbo.
manifold.
pipework.
intercooler.
programmable ecu.
downpipe.
injectors.
fuel pump.
there will be more stuff that i cant think of, but that should get you started :)
stembo21
Post Tue May 05, 2009 7:58 pm
will i need to put a decomp plate on it?
maxfield
Post Tue May 05, 2009 7:59 pm
No.
stembo21
Post Tue May 05, 2009 8:36 pm
this this for both the erley and late one? how come the compressin ratio is so different? how will i know what mine is its a f reg
EddyE30
Post Tue May 05, 2009 9:00 pm
Can anyone point me i the right direction to some good build threads for this conversion
i can't seem to find much information on the subject
what size injectors are people using for 300 hp and what psi of what turbo T4 ?
Eddy
Gunni
Post Tue May 05, 2009 9:38 pm
check out www.e30tech.com´s forum.
Tons of E30 turbo builds.
Standard internals will handle 450hp no problem.
9.7:1 compression engine requires a 0.120 MLS gasket and ARP headbolts to survive
while the 8.8:1 engine will do it on paper gasket + ARP bolts.
Go for 450cc injectors and no less.
You should reach 270hp at about 9-10psi on a stock B25.
Gunni
@ 2012 VEMS group buy !!
gooner1
Out humping Reindeer
Post Tue May 05, 2009 9:45 pm
Take a look at the diagnostic plug, near the dipsstick.
On the early blocks they are kind of D shape, whereas the later ones are more O shape. Probably loads more ways that someone
else can point out.
EddyE30
Post Tue May 05, 2009 11:01 pm
Gunni wrote:check out www.e30tech.com´s forum.
Thanks mate thats a great help :)
stembo21
Post Thu May 07, 2009 7:22 pm
i think the worst thing eill be the downpipe cos the steering rack is in the way wots the best manifols to use
Gunni
Post Thu May 07, 2009 8:52 pm
The downpipe is easy enough.
Even for a big log manifold and lhd.
Gunni
stembo21
Post Thu May 07, 2009 10:10 pm
wot is the best manifold to use i have seen some on ebay are they any good
fowler
Boost Junkie
Post Fri May 08, 2009 5:34 pm
exotic performance manifold is prob one of the better ones
EX A-Tech Workshop bitch !!!
gone but not forgotten
