Beemerlad's M52 Chromie
Post Sun Aug 02, 2009 11:13 pm
E30BeemerLad wrote:I'll have a deal with you on that flywheel & clutch Steve
no prob fella not sure when i will be over that way next, will let you know , or of course you can collect
almost went to york dragway today winkeye
Omi
Witty custom rank.
Post Sun Aug 02, 2009 11:43 pm
You need the starter for the M20 too, Lee. - Sorry I wasn't more help today, wasn't prepped for getting filthy.
Didn't take you long to serve up the exhaust!
...or is it?
stonesie
Post Tue Aug 04, 2009 10:43 pm
I have a spare 325 starter motor, untested as yet but thats soon sorted if your interested?
Andyboy
Alpina Colada
Post Tue Aug 04, 2009 11:10 pm
E30BeemerLad wrote:
So much Council activity.
Dezzy
CR24v it's a lifestyle
Post Wed Aug 05, 2009 10:12 pm
Thanks for the motor Lee and the coffee. Done me proud again with the rad too. Cheers dude.
Post Wed Aug 05, 2009 10:33 pm
no probs mate, my pleasure, helping each other out, that's what it's all about.
Was funny pushing the scrap out onto the road (both of them), propshafts knocking all over the shop :)
Dezzy
Post Wed Aug 05, 2009 10:37 pm
I know I could feel the eyes burnng into the back of our heads. I could almost here your your neighbours say he better not be leaving them there ha ha
waze30
Post Fri Aug 07, 2009 2:04 am
great thread this,well done for sticking with it im sure id have just torched it
Andyboy
Alpina Colada
Post Fri Aug 07, 2009 12:23 pm
The neighbours knew the area was going to the Dogs when the Soarer turned up.
"Mildred! Some import Rice has infiltrated the avenue. I'm writing a stiff letter to the Mail."
If anyone wants a really nice 2.5 M50, I have one. :D
Post Sun Aug 09, 2009 10:08 pm
Got home after a weekend away and took a few bits off the M52, like the rocker cover & coils etc, ready for the new gasket, cams look mint. Took the sump off too. One of the bolts for the oil pickup near the oil pump is a right cnut to get to.
I assume I remove the windage tray which is bolted to the bottom of the block. Do the bolts that hold that on do anything else (do i bother putting them back in or not?)
Got to pick up the sump gasket and rocker gasket from the stealers and then I can get this sorted and plug the loom up. Then need to get the M20 flywheel, starter & clutch off Steve so i can get this lot back in the car.
Need to order a spigott bearing too.
Getting there
Dezzy
Post Sun Aug 09, 2009 10:25 pm
When i fitted mine i removed them and left them out of the m50 mate therer is one in the e34 sump isnt there. I am using that loom i got off you now mate because i am have messed the one i tried to do up. Worked this out by pestering Dan all day on thrusday. Fingers crossed it will just start once its fit. Whats the plan next lee whats left too do?
Post Sun Aug 09, 2009 10:39 pm
Mine fired first turn of the key with that loom I got off Dan, so should be bullseye mate 8)
Yeah the E34 sump has a windage tray, just wanted to know what to do with the bolts and if they served any purpose other than holding the windage tray on.
This week, the plan is
Fit sump (when I collect gasket)
Fit rocker (when I collect gasket)
Fit new plugs
Change over alternator
Collect M20 flywheel, clutch & starter & fit them
Bolt the box back on
Fit the S50 exhaust manifold
Fit the loom
Drop it back in :)
Post Sun Aug 09, 2009 10:41 pm
The bolts have to go back in Lee, there are triangular supports onto the crank caps that these hold down.
Dezzy
Post Sun Aug 09, 2009 10:47 pm
Is that the same on the M50 dan as i didnt put back in and am sh*tting now
Post Sun Aug 09, 2009 10:48 pm
Cheers Dan, legend!
I thought they looked a bit too substantial for holding a bit of tin in place.
PM me your address so I can send the E36 loom over to you. I do use both lambdas on this don't i?
Dezzy
Post Sun Aug 09, 2009 11:02 pm
On the m50 they are just m6 bolt that only bolt through the tray. I think I am ok
Daf318is
Post Sun Aug 09, 2009 11:33 pm
Well Lee - I spent a couple of days this weekend on my car and I took the old M50 out, swapped everything over and stuck the new one in and went to the pub! There's no excuse this car should be finished by now winkeye
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
Post Sun Aug 09, 2009 11:51 pm
If i hadn't been away since Thursday and had the gaskets and fly etc I would have had this in & running this weekend :(
e30bmlover
Ac Schnitzer prophet
Post Mon Aug 10, 2009 1:31 am
shit you have been busy mate!!.. i love how zi m50 hanged there in shame!! the m52 will serve you well! when you coming to norfolk?? is it this coming weekend?? when you get her done you will have to bring it down so i can drive it!!
Post Mon Aug 10, 2009 10:23 pm
Was down last weekend mate, sorry just ran out of time to pop over.
e30bmlover
E30BeemerLad wrote:Was down last weekend mate, sorry just ran out of time to pop over.
never mind... bring the m52 when shes completed... she will be rapid..lol
Post Sun Aug 16, 2009 8:02 pm
Well a bit more of the usual slow progress made today. We had company over yesterday so couldn't get anything done then and I didn't get started until about 1pm today.
Fitted the new cam cover gasket set and chucked in 6 new NGK's & refitted the coil packs etc.
The set about taking off the windage tray which attaches to the bottom of the block and removing the E36 oil pickup pipe, the only way I found I was able to do this was by removing the oil pump due to where one of the pickup pipe bolts is located. Went to fit the E34 sump and found that the windage tray in the sump fouls on the main bearing support brackets, so a quick phone call to Bob-S to check I wasn't going mad confirmed I needed to drill out the rivets in the sum holding the windage tray in.
This was a success, only I then spent a good half-hour cleaning all the swarf and metal filings out of the sump with white spirit and the airline.
Fitted the sump up with new gasket and plenty of blue Hylomar just for good measure.
Went to fit the M20 flywheel & clutch and found that some webbing needed removing from the end of the sump as it fouled the flywheel, so the angle grinder gave that the good news and I got the flywheel bolted up and loctite'd on, clutch on and centred up and bolted up.
Then fitted a new propshaft guibo and bolted the gearbox up.
Just got to bolt on the starter motor and then get the exhaust manifold fitted and the wiring loom and a few other bits and it'll be ready to dangle it over the engine bay again.
5 weeks until the pod :?
Dezzy
Post Sun Aug 16, 2009 8:09 pm
Been waiting for this mate. Nice work surely you could have fitted the s motor and loom it's only a few more mins. 5 week till pod is scary isn't it pick up wings and door pods and side skirts on Tuesday and drop bonnet and bumpers off. Waiting for prop and some other bits of a mate then we should be golden.
Post Sun Aug 16, 2009 8:11 pm
Yeah I could still be out there now but it wasn't fair on the missus, got to keep the balance right :)
Dezzy
Post Sun Aug 16, 2009 8:19 pm
Oh yeh I have had that conversation many times. I have been given set days now that I am allowed out to play ha ha.
Post Sun Aug 16, 2009 8:22 pm
same here mate, Sundays and Wednesday nights :)
Dezzy
Post Sun Aug 16, 2009 8:23 pm
I have Monday and Tuesday while she is at the gym and Sunday mornings ha ha. Pair of pussys arnt we :cry:
Post Sun Aug 16, 2009 8:27 pm
Lol yeah, it's a bit of a ball ache, but I suppose also that there is more to life than these old pieces of scrap really, hell I was aiming to be at the pod with mine last year :) :)
Dezzy
Post Sun Aug 16, 2009 8:33 pm
Ha ha mate I know. I need keeping in line my wife tells me. If I don't make the dead line i will have to go in the Leon. Should be done like
Post Mon Aug 17, 2009 10:06 pm
Got the starter motor bolted on tonight, put the front pulleys back on and also fitted up the S50 exhaust manifold, started plugging in the engine loom and need to fit the M50 inlet manifold. Quickly got confused by the wiring loom and guessing what plug went where lol.
Can't work out where the 2 lambda sensors plug in, Dan?
Dezzy
Post Mon Aug 17, 2009 10:10 pm
Ha ha what are you doing out on a school night mate. Busy night for dan I have just sent out an SOS as well. I was out for a bit earlier too mate. Didn't make as much progress as you though pal. Good effort
Daf318is
Post Mon Aug 17, 2009 10:45 pm
I think Dan should set up a hotline for the M50 boys on here winkeye !
Post Mon Aug 17, 2009 10:51 pm
Lambda sensor plugs clip onto the top of the fuel rail, see here -
Rear sensor cyl 4-6 uses the front plug and the front sensor cyl 1-3 uses the rear plug
Help and guidance can be bought/paid for with stella :)
Dezzy
Post Mon Aug 17, 2009 10:52 pm
Daf318is wrote:I think Dan should set up a hotline for the M50 boys on here winkeye !
+1 but it better be 0800 or i will be skint
Post Mon Aug 17, 2009 10:53 pm
I'll sort you at the pod fella, how do I know which sensor is which though as I've transferred them from the M52 manifold to the S50 manifold and obviously didn't pay any attention :)
