Lsd options
Corasdad
I have swapped in an m52 and i am thinking it might need an lsd what options do i have other than an e30 lsd which seem to be like rocking horse poo
rix313
188 spools were in E34 and E36s. These fit inside E30 188 cases but need to be fitted and shimmed correctly by a specialist. You can look at something like a geared unit like a Blackline. Cost effective and low maintenance so good for a road car. This will still need the same shimming and set up as fitting an OEM plated spool. LSDs are not a cheap game.
Corasdad
Do you shim them or just supply the lsd unit
