Bit of an odd one to me... I seem to be losing coolant but have no idea why or where from...
It is also not consistent loss... I noticed the light was on so checked and the coolant tank was practically empty... filled it up and have driven 25miles and all good so far...
Any ideas / suggestions?
Coolant leak...
Satan
Check the hose and connection under the coolant tank also check the tank for any hairline cracks.
All these hose have a tendency to shrink, perish and start to leak. If you can't find the leak you can buy a UV dye to put through the system.
blazed
also worth checking your heater valve isn't leaking
j4gz
also check the water pump hose that could be catching on the fan and made a hole .
As in the footwells ?blazed wrote:also worth checking your heater valve isn't leaking
blazed
Indeed, i should have said heater valve and matrix.
