Hi,
I've just had my new sump gasket delivered from Cotswolds. Should I use sealant?
If so, which type?
What is the torque for the bolts when putting back on?
Thanks a™‚
M20B25 sump gasket question
Jona1971
Moredoor autos with small engines are cool - but my new m20b25 is awesome!
BenHar
Jona1971
That is very useful! a™‚
maxfield
Shouldn't be any need to use any sealant, aslong as both surfaces are nice and clean.
chu346
Thats right, but last time I did one it leaked a littlemaxfield wrote:Shouldn't be any need to use any sealant, aslong as both surfaces are nice and clean.
If sealant is used, keep it to a minimum. Excess sealant that is squeezed out inside the sump tends to form little balls that are very effective at blocking the gauze on the oil pick up pipe.
maxfield
If you have to use a sealant, I would use hylomar blue. Is a non setting compound, but is good stuff.
Jona1971
Thanks chaps a™‚
Yeti
thin bit of hylomer you should be good
