Hi guys,
I am new to this game... just purchased an E30 316i tourer, a little under powered i know but an immaculate car.
The problem is my head is touching the roof with the seat fully down when i am in my upright sitting position.
Does anybody know a way around this??
*I AM 6FT
I have a long drive to Edinburgh at the weekend and dont fancy slouching all the way there!
Jordan
Head touching roof of E30 tourer...... please help?
Have you found the seat up-down adjustment/is it working? Push down the lever by the seat hinge.
Jordanjames
Yes its fully down, i also checked the passenger side and its the same there.
I have a saloon that does not have a sunroof and i have no problems in this.
I understand the roof is slightly lower for the sunroof but there must be some way around this?
Theres no distance in non or sunroof roofs, one zoner kieran is 7ft tall or something he hasnt got a problem in his sunroof cars, it must be your seat adjustments !
Jordanjames
I will double check again but it seems odd that both passenger and drivers seat is the same.
The drivers seat is a spare from an old E30 i took apart.is there something i can do to set it to a minimum before i put it on, then when i put it on lower it further with the leaver?
RM2186
gooner1
- Out humping Reindeer
Liposuction? a˜€
heathy325
Defo your seat as above I'm 6ft 6 and no problems in mine
Nobby_N
Recline the back of seat
Jordanjames
Hi can I ask if you have the back of your seat upright??heathy325 wrote:Defo your seat as above I'm 6ft 6 and no problems in mine
I can not sit at an angle due to a pelvis injury
Thanks jordan
I'm 6'3" and have no issues with height adjustment in my touring - also don't have the seat leaned that far back either.
As above it sounds like there is a problem with the height adjuster
Jordanjames
Just had the car checked by a E30 enthusiast and the seat is fine. It has full height adjustment motion and is level with the passenger seat (which I also touch the roof in) However my friend is 6ft2 he sits in the car with half an inch clearance, I must have a really long body and or big head.
Is there any way of cutting something of the bottom of the seat and welding it back together but shorter?
thanks again!
thanks again!
