Hi, I have just managed to get my e30 cab on the road. Now I'm finding that it had a blown fuse in slot 17 (electric windows). I replaced the fuse several days ago and it's blown once again.
Any ideas as to the fault, sorry for scant information.
Flute.
My cab keeps blowing fuse 17!!!
- Brianmoooore
Usual problem is metallic debris inside one of the window switches.
Hi flute I got the same problem I posted and got a few replies on a thread in the week, I replaced my window isolator switch and that solved part of the problem the next I was advised that a green wire off the starter motor could be corroded and may need to be replaced I haven't checked this myself and there are two fuses 17 & 28
- Brianmoooore
Both these faults will result in no power reaching the windows, but neither will blow fuse 17.j4gz wrote:Hi flute I got the same problem I posted and got a few replies on a thread in the week, I replaced my window isolator switch and that solved part of the problem the next I was advised that a green wire off the starter motor could be corroded and may need to be replaced I haven't checked this myself and there are two fuses 17 & 28
