A up guys has anyone experianced this issue? Can anyone shed any light on it? Im not sure how these are assembled... could it be a worn bush/loose bolt??? Cheers guys
Gear stick problem with video
Nato_e30
M1k3
There's a locking tab either side ( near your fingure ) couple of flat screwdrivers or try to twist the white part anti-clockwise.
Nato_e30
Will that sort the silver bit out mate? The part that looks asthough it should be mounted solid the the body?
cakey87
theres a small metal bracket underneath the car with a bush/grommet on, cast bit the the gear lever goes through has a spike on the end that sits in this bush, either the bolts have come loose or the bush has gone, get yourself underneath it and remove the heatshield above the prop shaft and u will see it.
Nato_e30
Shit hot thats great mate many thanks
cakey87
no probs fella, its an easy enough job aslong as u can get underneath, ill see if i have any pics of when i did mine, so u have a better idea what your looking at,
cakey87
http://imageshack.us/photo/my-images/689/img0530c.jpg/
check that image link out, gives u a bit of a better idea how it works.
M1k3
Sorry mate I didn't see the video only the picture. That's pretty bad, my bet would be the nut has come loose or fallen off.
Nato_e30
Aaaah I see that makes it clearer, the last track day I did I shifted from 3rd to 2nd and it went then, its never been brill, ill get under it next sat and take a look, cheers for the help guys
Nato_e30
Chances are that the engine and gearbox mounts are knackered and the lump has moved forwards under hard braking and pulled the rear locating spigot from its bush.cakey87 wrote:theres a small metal bracket underneath the car with a bush/grommet on, cast bit the the gear lever goes through has a spike on the end that sits in this bush, either the bolts have come loose or the bush has gone, get yourself underneath it and remove the heatshield above the prop shaft and u will see it.
