which one should i have?
johnono
Post Mon Feb 07, 2005 9:52 pm
i want a new ignition rail.
there are 2 for the 2.0 m20
first is with something called a DME?Image
the other is without the DME
what the score dudes, and wtf is a DME
Ant
Retired Team Member
Retired Team Member
Post Mon Feb 07, 2005 9:59 pm
You want the with DME set , the other set is for a Jetronic 320 with mechanical dizzy ignition
new leads always look cool :lol:
Post Mon Feb 07, 2005 10:01 pm
are they hard to change? where from the dealer? bling bling?!
johnono
Post Mon Feb 07, 2005 10:44 pm
gonna cost me 120 notes brand new, and its a pull n plug job...i think :lol:
fancy a new set, may not need it, and then a new dizz and rotor.
jets are out of my leauge right now so weԚ´re going easy..till she stops watchin me :wink:
Post Tue Feb 08, 2005 12:34 am
The thing attached to number one plug lead can be cut off and thrown away. It's only required for dealer diagnostics.
johnono
Post Tue Feb 08, 2005 12:40 am
which?, the plastic cover thing?
Post Tue Feb 08, 2005 1:17 am
The bit with a 2pin plug on the end that goes around the front of the engine and into a socket under the diagnostic connector.
A1BMW325iSport
Post Tue Feb 08, 2005 8:23 am
don`t the early 325`s had non dme leads?
Templ8e30
Post Tue Feb 08, 2005 6:03 pm
I wouldnt cut that wire if i were you, my dad had an e30 years ago that started to run rough and it turned out that this wire had broken off the ignition lead.
Fitted a new one and it ran fine.
Cheers,
Iain T
greg325
Post Tue Feb 08, 2005 6:23 pm
what ever you do , don't ! i said don't cut that wire !! it would just equal throuwing the loom away after having bought it new.
so , this wire , is not just diag, it controls your ignition on the motronic version....cut it the car wount run ! ; if it does you might result in pinging, to much advance ... and it all run all injectors at the same time ...making extra consumption.... :mad:
the first pics is for the version with the ignition on the camshaft...i mean the motronic then...
the second is for the ljetronic type 1 with the distirbutor cap aside the bloc and mounted on the oil pump axle...
cheers
A1BMW325iSport
Post Tue Feb 08, 2005 6:32 pm
the 2 pin plug on mine is not connected and it runs fine
Richy325iTouring
Post Tue Feb 08, 2005 6:43 pm
not conected on mine and runs fine
my leads i took off my d plate as they were new and i wernt buying new again when i bought the touring.
They were only a week old.
johnono
Post Tue Feb 08, 2005 6:47 pm
u put jettronic cables on a motronic engine and it works?
cool
greg325
Post Tue Feb 08, 2005 8:37 pm
blug it back in before you bust the low end... and it will incress your millage :;)
if your car does run it certanly is not optimal trust me.........dyno tested that one too 8)
and i never said you could invert the 2 sets... :mad:
Post Tue Feb 08, 2005 8:41 pm
My Motronic wiring diagram shows the pick up on ignition lead 1 as only going to the diagnostic plug, BUT, I just went out to the workshop and had a look at a partly stripped loom from a 89 320i, and the lead in question goes all the way to the ECU, so I think I will retract my advice to chop it, as on some versions of Motronic it looks like it may have important functions after all. There's always something new to learn.
Simon
Post Tue Feb 08, 2005 8:51 pm
This lead cured a rough running problem on my old 316i too, I spent loads changing various things and all it was was this lead.
greg325
Post Wed Feb 09, 2005 12:30 am
on the late model of motronic that leads tels the ECU what injtecor to run as it detects when the 1rst ignition wire recieves the curent...if its not plug in in most cases it would only result in getting all the injectors to flow at the same time , meaning less milage and wrong mixture...so less power and bad idling.
it also controls whan the exact moment the spark is made to get on spot the correct timing...if it of , after a while, a bad ecu with a unpluged lead can cause the enging to ping....
my little evening contribution... :wink:
johnono
Post Wed Feb 09, 2005 12:33 am
ok then, its settled, without DME.....haha, your face :mad:
with DME it is then.....nice one lads for gettin ya teeth into this one! :cool:
