broken e30 325i....help
leeparkes
Which rocker broke?
If its near number 6 cyl its easier to change as the rail slides out only a bit to swap the rocker. If its on number 1 cyl the rail has to be slid right out and other rockers removed to get to it.
BUT if you have a broken rocker you will be very lucky not to have a bent valve to go with it.
jimbom30cab
- Tech 1 freak
yer, changing the head for a good one sounds best bet to me, plus the added benefit of having a nice new head gasket. The zone is great for this stuff, it wasn't that long ago when a replacement head would have cost mega bucks.
have decided to change head as number 4 rocker broke.on inspection yes the valve was bent,the whole head was a bit shot really.got a head off a zoner seems okay apart from 2 exhaust valves not wanting to come out the guide,the tops had mushroomed .can i reuse or are the tops now weakened? should i replace?
