heated washer jets
gazza
how do they work ....do they heat up when the washers are operated or do the run hot all the time. (i had some on a car before and they came on when the heated rear screen/mirrors were operated) i have a cab so no heated screen or heated mirrors ....cheers
Templ8e30
Hi Gazza, the heated jets have power all the time the ignition is on. The jets have a thermistor inside them that stops them from heating when not needed and prevents them from burning out. I think they start to work at about 5 celcius.
They don't get warm enough for you to feel the heat but they do work very well.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Demlotcrew
Are you sure?Templ8e30 wrote:Hi Gazza, the heated jets have power all the time the ignition is on. The jets have a thermistor inside them that stops them from heating when not needed and prevents them from burning out. I think they start to work at about 5 celcius.
Cheers,
Iain T
Andrew
Steviec
Were there certain models these came on, or was it just an option across the range?
Demlotcrew
All M3s had them as standard.
Andrew
Andrew
A1BMW325iSport
i have them on mine,
gary as i said when i spoke to you earlier i thought they worked with heated mirrors/screen
gazza
cheers lads the reason for this post is i thought they would be a usefull option wth winter on its way but i have a cab and it does not have heated rear screen or heated mirrors so i wondered how they switch on. the etk shows the loom connects or runs close to the reservoir and it looked like when you use the washers it feeds power to the jets to heat them. i have the jets, and the loom is still available at bmw for about 17 quid.
A1BMW325iSport
i can trace the loom on mine for you mate, but it will be weekend as i`m out all day 2moro
johnna
- E30Zone Irregular
Hmmmm retro fit..... Ԛ£17 Loom from the dealer?
Bargain! Are they tough to retro fit?
Dan318-is
i was also wondering how hard to fit?
A1BMW325iSport
jet parts just clip in, mine were factory fitted.
i`ll have a look at the loom i`m pretty sure there is not much to it
Dan318-is
cheers mate
n e indication as to were it goes would be grand
A1BMW325iSport
2 pin plug goes to each washer jet, then the loom goes down bonnet to hinge area on drivers side, and connects down there i`ll have a look 2moro and tell you more
Dan318-is
a true hero matt
sabrje
Any idea of the part number for the loom - sounds like a good upgrade....
e30bemer
- Nutters
Part no:
61.12.1.380.673
Ԛ£17.96+vat
Gotta be ordered from Germany!!!
Hope that helps
Adam
61.12.1.380.673
Ԛ£17.96+vat
Hope that helps
Adam
sabrje
Spot on - cheers. Time to give the stealers a call.....
e30bemer
- Nutters
no probs mate!!
Demlotcrew
They dont work very well at all!
You need to mod them for full effect.
Andrew
Andrew
NigelA
What does one need to do?Demlotcrew wrote:They dont work very well at all!
Andrew
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
Demlotcrew
Well i connected mines to a acc live and put a Thermo switch in the circuit from a E36, what this means is that when the temp gets bellow a certain level the jets will heat up, this is good as wind chill freezes them also.
Andrew
Andrew
oze30
Now for thjose that don't speak "demlotcrew"Demlotcrew wrote:Well i connected mines to a acc live and put a Thermo switch in the circuit from a E36, what this means is that when the temp gets bellow a certain level the jets will heat up, this is good as wind chill freezes them also.
Andrew
GDBN
Gaz ... why does your cab not have a heated rear screen? I thought the warm air blower was standard on cabs.
Heated mirrors were an option ... but it's useful to have.
G
G
nickso
- Location: Go do that voodoo that you do so welllllllll!!
the ones i swiped off a well specced 325 were just linked into the live for the washer motor.
should work well enough in my car cos the washer bottle get heated by my top hose
'88 e30 328i M52 track bint.
Project_E30
oze30 Do you want a set as I have a pair for sale.
You will
at the price the dealers charge for the actual washer jets
You will
gazza
gdbn said ...Gaz ... why does your cab not have a heated rear screen? I thought the warm air blower was standard on cabs.Heated mirrors were an option ... but it's useful to have.
it does have the rear blower this is a very old post if you look at the date ....i wanted to know if mine were working ....they are
design cab and now 325 touring-
oze30
I have already. just wanted to know how he wired it up
jmc330i
You willProject_E30 wrote:You willat the price the dealers charge for the actual washer jets
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
gazza
i bought a new loom to make them work cost Ԛ£17 but i think the jets were about Ԛ£17 each
