Fueling Problem on 320i L-Jetronic
What happens when you start it and try revving it?
It just revs a little and cuts out
Perhaps try getting someone to rev it while you spray in Easy Start - perhaps it just needs to 'clear it's throat'...
Also, I take it you have the in and out fuel pipes and fuel filter on the correct way round?
Couldn't find a friend so got the wife instead lol
Here are a couple of videos. The first is without any easy start and the second I get it up to 3000 revs and apart from initial alternator bearing scream its the best I have had for a while.
I had to publish them on youtube as couldn't attach them here
Apologies for any rude words used as its just frustration!!!
Good going, but I would have been tempted at that point (at the end of the second video) to inject some more Easy-start in the inlet manifold then replace that pipe prior to having another go...
Thanks Maurice for your reply. I will ie it another try and for longer net time. I just didn't want to over do it and the smell of the fumes was a bit overwhelming at that point so I thought it would be prudent to wait. But at least it is progress!!!Speedtouch wrote: ↑Sat Jul 05, 2025 9:51 pmGood going, but I would have been tempted at that point (at the end of the second video) to inject some more Easy-start in the inlet manifold then replace that pipe prior to having another go...
Yes, at least you've now had it running for a few seconds and it sounded quite healthy. What is what appears to be a half inch or so diameter inlet/outlet pipe under the rubber hose, and what is the red cap for?
Not sure what you mean by the half inch inlet/outlet pipe or the location you mention? could you please clarify and the red cap you mention is fitted to the Idle Control Valve as a blank cover stop or bung and has always been thereSpeedtouch wrote: ↑Sun Jul 06, 2025 8:56 pmYes, at least you've now had it running for a few seconds and it sounded quite healthy. What is what appears to be a half inch or so diameter inlet/outlet pipe under the rubber hose, and what is the red cap for?
The bit that looks like an inch or so long tube sticking out in the centre of the screen in the second video - perhaps there's supposed to be a breather hose attached?
Where the little red cap is - For reference the vacuum pipes on the cold start unit side on the manifold go to the fuel pressure regulator and the other to the partial load switch mounted on the NS, on the air cleaner box. See attached photo and diagram.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
Useful to know - thanks for posting. I saw a similar version t'other day when researching this, but it was in German! Do you still own this immaculate example?
I'd suggest ensuring these items are looked at again - does it even have an FPR fitted now?
I do indeed. It’s even nicer now it’s tax free!Speedtouch wrote: ↑Mon Jul 07, 2025 5:13 pmUseful to know - thanks for posting. I saw a similar version t'other day when researching this, but it was in German! Do you still own this immaculate example?
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
Excellent - the more, the merrier.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
'11 X3 3.0d SE
'89 240 DL Estate
Your car looks fantastic!!! Anyway thank you fro the information and diagram I looked at the pipe you mentioned and it goes into the side of the breather hose on top of the rocker cover (see photos) Not sure if there is a check valve here or not but does not appear to be a Partial Load switch as shown in the above diagram
- Attachments
And does it have an FPR fitted now?
Thanks for your message and Yes it does have one. Sorry I don't understand why do you think it hasn't got one?
What year is the car? There were quite a few changes to the L-Jetronic in later years and may be why there are differences to Hennabm's early car and mine.
- Contact:
How long before changing the pump, weeks/months/years?
Did you test the fuel pressure while cranking the engine over or shorting the pump wiring? While cranking the engine gives a better idea of if it continues to run or not.
Your test with spraying easy start and it running for longer would indicate a fuel problem.
Thanks or your reply pump recent and the rest of the info is listed in my post. Fuel Pressure has been tested and is ok going to do another running test soonDanThe wrote: ↑Wed Jul 09, 2025 8:15 pmHow long before changing the pump, weeks/months/years?
A 1985 car would normally be on an A- or B-plate; D-reg was c.1986/7.
To be pedanticSpeedtouch wrote: ↑Thu Jul 10, 2025 10:49 pmA 1985 car would normally be on an A- or B-plate; D-reg was c.1986/7.
These days with unreliability and scarcity of parts for these old Jetronic cars, if they start to cause problems then best advice is to fit Motronic. Exactly what mine is getting
Good idea, or even Megasquirt or similar.
