gearbox chatter?
sweep
Thu Nov 24, 2011 11:02 pm
as above is there any fix for this? stripdown?can i get the parts from the dealers??
Thu Nov 24, 2011 11:07 pm
a noisy Layshaft is common Pete, usually due to the tickover being too low ? it will still last forever :D
Thu Nov 24, 2011 11:21 pm
Using the correct oil helps. Not ATF!
leeparkes
Thu Nov 24, 2011 11:24 pm
What is the correct oil? both my cars have ATF. 8O and the layshaft is a bit rattly on the E30 :?
clipper
Fri Nov 25, 2011 8:27 am
bss325i wrote:Using the correct oil helps. Not ATF!
Doesn't help that much !
I speak from recent experience !
Mikey_Boy
Fri Nov 25, 2011 10:10 am
^^^ +1!!
Use of ATF is a daft idea... :mad:
Layshaft is definitely the issue here - cured with a rebuild but if you are prepared to put up with it, it will last a looooooong time without going wrong. Putting up the idle speed a touch works wonders!! winkeye
Andyboy
Alpina Colada
Sat Nov 26, 2011 4:31 pm
The correct gearbox oil for an E30 is EP80 although you can use a non multigrade SAE30 engine oil.
ATF Dexron makes it rattle, and EP90 can make it hard work to change gear.
sweep
Sat Nov 26, 2011 4:33 pm
i think il take the box out and fit new bearings if they are avalible il look on real oem.
Sat Nov 26, 2011 5:52 pm
I have used EP80W90 or EP80, both are fine.
Sat Nov 26, 2011 5:56 pm
Oh and as for ATF, i tried it years ago upon recommendation by a well known Kent based BMW specialist as a cure for stiff gear changes when cold.
Yes it worked but when hot it was to noisey so i changed back to EP80 and its been fine since.
M42
Sat Nov 26, 2011 10:47 pm
I had a same the same problem on the M3 and was recomended MTL redline transmision oil, completley stopped the rattle. very good stuff. I think Demon Tweakes sell it.
BMWE30325
Sat Nov 26, 2011 11:02 pm
bss325i wrote:I have used EP80W90 or EP80, both are fine.
http://www.ebay.co.uk/itm/DX-Three-Hypo ... 2a15d69bb4
one of these?
mrb27
Sun Nov 27, 2011 12:32 am
on mine, when at idle i get a rattle from the box, if i put the clutch down it stops, but let it back up and it goes again :(
would that be the same thing?
Sun Nov 27, 2011 12:35 am
mrb27 wrote:on mine, when at idle i get a rattle from the box, if i put the clutch down it stops, but let it back up and it goes again :(
yes
can also be the clutch release bearing
mrb27
Sun Nov 27, 2011 1:15 am
bearing and clutch replaced a few weeks back, what can i do to sort the rattle?
new shaft bearings?
sam325is
Wed Nov 30, 2011 11:40 pm
bss325i wrote:Oh and as for ATF, i tried it years ago upon recommendation by a well known Kent based BMW specialist as a cure for stiff gear changes when cold.
http://www.amsoil.com/storefront/atd.aspx
Use this. it hardly thins with temperature. No rattle on start up and smooth gear changes. Once fully warmend up the rattle is still there a tiny bit but overall it makes a massive improvement.
I bought it from oilman.
Wed Nov 30, 2011 11:48 pm
Thanks for the recommendation but i'll stick with the correct EP80 as i dont get any chatter now on idle at any temp.
sam325is
Wed Nov 30, 2011 11:56 pm
Thats good :) a happy gear box. But i meant for sweep. Also its worth taking not of the colour of the sticker on the housing of your bear box. Some of the manual gear boxes are supposed to have ATF in them.
Thu Dec 01, 2011 12:07 am
That's correct, some manual trans are meant to use ATF but the getrag 260 used in the 325i is meant to use convertional EP80.
Andyboy
Alpina Colada
Thu Dec 01, 2011 5:17 pm
Years ago, I had a Cortina with a layshaft rattle that would wake the dead. Draining and refilling it with EP140 made it quieter...........
