Fire Extinguishers
Post Sun Aug 29, 2021 3:08 pm
I found this in my wifes 2001 polo and it`s now all mine !!
Has any one pics of how these should fit under the drivers seat please ?
I know it`s not OEM but I wont tell if you wont winkeye winkeye winkeye winkeye
Cheers Mart.
Cloggy Saint
Post Sun Aug 29, 2021 3:24 pm
You'd probably have to fabricate a custom bracket to get it to fit under the seat.
Post Sun Aug 29, 2021 3:32 pm
Didn`t we have a post about this recently ?
It`s all about how it looks so I can make something at work, so if you or any one has pics of how it should be then I will be very happy !!
Cloggy Saint
Post Sun Aug 29, 2021 3:37 pm
The oem item is a horseshoe shaped frame with a cradle at the front to hold the extinguisher. The whole assembly then bolts to the underside of the seat using the pre-existing holes. Remove one of the seats and it all becomes fairly obvious.
Post Sun Aug 29, 2021 3:42 pm
Cloggy Saint wrote: ↑
Cheer mate, I`ll have a look at this :cool: :cool:
flybynite
Post Sun Aug 29, 2021 6:07 pm
martauto wrote: ↑
Here you go :D
onthames
Post Sun Aug 29, 2021 7:51 pm
flybynite wrote: ↑
martauto wrote: ↑
Here you go :D s-l1600 - 2021-08-29T180545.652.jpg
Good luck getting one for less than 250 :(
flybynite
Post Sun Aug 29, 2021 7:59 pm
onthames wrote: ↑
He has an extinguisher already, Mart is only looking for a picture of the bracket. It is simple enough design and I'm sure he can knock one up at work for a couple of quid :D
New the extinguishers are only about £60 or much less if you don't mind not having the BMW logo :thumb:
onthames
Post Sun Aug 29, 2021 8:15 pm
flybynite wrote: ↑
onthames wrote: ↑
It's the original bracket that's expensive, with the retaining clip etc
flybynite
Post Mon Aug 30, 2021 8:46 am
onthames wrote: ↑
Agreed, if you want an original, in good condition (possibly even working) then yes they are expensive. There is one in fair condition on ebay now for £170 so they do come up.
But every new 1kg or 2kg extinguisher will come with a mounting bracket. A brand new 'Gloria' extinguisher (which BMW use) will come with a mounting and retaining clip. It is different to the old one being a simple mount and plastic retaining strap but works and can be bolted to the metalwork like the old full 'cradle' mount.
For anyone who is adept at metalwork, the seat mounting bracket would not be a difficult exercise.
Now and again someone makes a batch and sells them on ebay, like this guy. (although he has run out for the moment) but you could probably get one knocked up for half of that.
https://www.ebay.co.uk/itm/164272327583
£45 for one of those and about £37 for one of these
https://www.safelincs.co.uk/2kg-powder- ... oria-p2gm/
Would give you a proper 2kg brand new extinguisher that works, mounted correctly for about £80
I would still carry a firestick in the glovebox
Cloggy Saint
Post Mon Aug 30, 2021 10:51 am
That ebay bracket isn't much use without the cradle to hold the extinguisher, or am I missing something?
twenty
Post Mon Aug 30, 2021 12:17 pm
Correct. You still need the extinguisher bracket - which BMW still sells new alongside with the extinguisher.
flybynite
Post Mon Aug 30, 2021 12:19 pm
Yes you are :D
As I said above in the post a new extinguisher, either aftermarket or a new one from BMW will come with a bracket to hold the extinguisher. Extinguishers are not the same shape so each one has a bespoke bracket for it.
The 'Gloria' 2kg one I linked to above even has captive nut keeps in the plastic to bolt them to the ironwork. I have one fitted in all my cars.
No-one makes a cradle-like bracket any more and if you have one it will only fit the '80s or '90s extinguisher it was made for
twenty
Post Mon Aug 30, 2021 1:06 pm
flybynite wrote: ↑
onthames wrote: ↑
Nice one. Definitely ordering one. New eBay listing at https://www.ebay.co.uk/itm/Fire-extingu ... 5044297603
twenty
Post Mon Aug 30, 2021 1:07 pm
flybynite wrote: ↑
Yes you are :D
So the Gloria is a straight fit into the eBay bracket linked above?
flybynite
Post Mon Aug 30, 2021 2:13 pm
twenty wrote: ↑
You are probably going to drill mounting holes as all the extinguishers have different mounting holes. My extinguishers bought 5 years ago have different holes to the one I bought last year. 2kg extinguishers are different to the usual BMW ones as they are only 1kg (BMW did do 2kg extinguishers as I have one) More chance of actually doing something with 2kg.
Post Mon Aug 30, 2021 3:51 pm
I stole it and fitted it to my Baur and I know it`s no where near OEM, but my Angle eyes after market headlights and the fact she is a Baur do not bother me winkeye winkeye .
A very 1980`s addition , just behind my drivers seat , on the door card and sit`s really tight to it.
I hope I never have to use it because it might rip the card when I tear it out in anger but I hope it`s never the case.
I have just bought one for the other side :cool: :cool: :cool: :cool:
Satan
Post Thu Sep 09, 2021 12:22 am
I have been driving for nearly 40 years and have never need to use an extinguisher
steve_k
Post Thu Sep 09, 2021 8:59 am
mart seeing as you are a tool maker i'm sure you would be able to drill new holes in the bracket if needed,
there's also this bracket which i'll be ordering myself in the next week or so,
https://www.tegiwaeuro.com/kap-industri ... -94-m.html
but if you look the holes are elongated so might not need altering to fit.
twenty
Post Thu Sep 09, 2021 9:10 am
steve_k wrote: ↑
I’ve ordered https://www.ebay.co.uk/itm/164272327583 as someone recommended it. Only realised that it’s LHD after ordering and seller didn’t respond so I’ll end up with fitting it on the front left seat I guess.
steve_k
Post Thu Sep 09, 2021 9:25 am
twenty wrote: ↑
steve_k wrote: ↑
well for £30 what have you lost?
twenty
Post Thu Sep 09, 2021 12:44 pm
steve_k wrote: ↑
twenty wrote: ↑
steve_k wrote: ↑
Indeed. Just surfacing this in case someone else is more picky than I am. I’m happy to have the extinguisher in the left seat and even prefer it.
Post Thu Sep 09, 2021 5:02 pm
steve_k wrote: ↑
I thought about it but rather like it in the back, no one sits in there anyway lol.
Cloggy Saint
Post Thu Sep 09, 2021 5:10 pm
twenty wrote: ↑
The seats are both the same, why would it fit on the left and not the right? :?
flybynite
Post Thu Sep 09, 2021 6:52 pm
twenty wrote: ↑
My mistake only noticed that myself, there was someone a while back selling ones that were RHD and I thought it was the same guy. 2 mins with a grinder and mig and it is reversed.
Small matter of the slide adjust handle that gets in the way. The bracket, including the OEM ones are slewed to one side.
Cloggy Saint
Post Thu Sep 09, 2021 10:48 pm
I used to have an oem extinguisher and bracket and I had it on both seats no problem.
twenty
Post Fri Sep 10, 2021 9:34 am
That’s encouraging. Let’s see when it arrives.
onthames
Post Fri Sep 24, 2021 10:52 am
Hi guys. The new fire extinguisher from BMW (same P/N as realoem) does NOT fit in the old bracket.
rix313
Post Thu Sep 30, 2021 10:05 am
I assume you bought one Sam? Do you have photos?
twenty
Post Thu Sep 30, 2021 11:46 am
That’s what the new stuff looks like. Received mine yesterday.
onthames
Post Thu Sep 30, 2021 8:44 pm
rix313 wrote: ↑
It wouldn't let me attach a video so here's some screenshots from video. The new one does come with its own strap on it and a small back plate that fits onto the metal bracket however doesn't fit into the nice sturdy OEM holder.
flybynite
Post Fri Oct 01, 2021 8:13 am
onthames wrote: ↑
But you are taking the new extinguisher out of its new holder and trying to push it into the one for the old extinguisher. Each extinguisher comes with a holder and you bolt that to the bracket.
Granted the holder for the new extinguishes is not the fancy 'cocoon' type like the older ones are but that is progress, lighter, cheaper.....but at least it will put a fire out.
Personally, having used these things in anger a couple of times anything less than 2kg is just eye candy
rix313
Post Fri Oct 01, 2021 7:30 pm
Ah not worried about it fitting in a standard holder as I not don’t have one anyway.
