Hi do my mirrors fold in manually ? please
1.6 i 1989.
can,t seem to move them.
thanks
folding mirrors sorry if duplicate post
Satan
Should do.
They did when the car was new! 'White rust' has probably seized them, so several doses of your favourite rust releaser required.
arrisbmw
cheers Brian , white rust ? whats that from ally
Satan
Ally flakes and sticks to other metals materials, try some WD40 wit PTF or ACF50arrisbmw wrote:cheers Brian , white rust ? whats that from ally
Is the paint pealing on the brackets?
Yeti
white from ally is the oxidization
arrisbmw
paint starting to peel on brackets, but not to bad, lubbed up with trans fluid has good creep, used a little black grease(c.v joint type ) on the metal moving part inside underneath. you need a bright light and close inspection
to see it, there is a dipple where the mirror housing sits in when at home position works fine now.
thanks you all for advise.
