Brake Upgrade Kit ......
sindako
Mates , What do think ?
Tomorrow i'll take my conversion plates from the forge ,
i am Upgrading the brakes of my e30 ,
Using E32 Calipers , with Auti TT 312mm x 25mm Rotors .
I Guess Now the Car will Have Better Brakes ,
I've seen E30 with EVO6 calipers and rotors , Subaru Calipers and Rotors , Mercedes w124 brakes and rotors .
But those TT 312mm are damn too good , So I am Goin For it ,
Also It's Amazing i don't have to Miss up with my Hub and the 4x100 diameter , just the conversion plates and Some Rotor Redrilling .
Photos Will Be Posted Soon .
Cheers .
Cheers .
clarko74
I'm just in the process of doing this conversion myself.
With calipers that big you'll probably need a larger master cylinder.
clarko74
sindako
I've Read about it somewhere online , And The Conversion didn't include any master cylinder replacement , I'll try it on the OE Master Cylinder , If It's Rubbish i'll get an e36 M3 one or maybe a 7 series one .
I'll hit the Realoem to see what cars had the same cylinder as the E30 , if the 7 series had the same then there'll be no problem .
Lurch320i
You don't want the same master cylinder as the e30 one
You need a bigger bore one with a larger piston inside
Did I comment on your post on Facebook?
Ant
- Retired Team Member
7 series E32 master cyl a must have on this I'd suggest
std m/cyl will work but long pedal bigger piston area means the m/cyl needs to displace more fluid per stroke to be an effective upgrade
Email FTW
satan16v
Do you need to change the brake flexis too?
I'm looking at doing this next year, and have Goodrich hoses at the moment, which I'd like to keep
Its either this or the Porsche 986 set up
But I want to find about the hoses before I commit
E30 325i - In progress
E53 X5 4.6is - SOLD
E46 320d Sport Tourer - SOLD
E36 M3 - SOLD
E34 535I Sport - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
Lurch320i
My braided hoses fit the bigger a calipers just fine
satan16v
Thanks Lurch
E53 X5 4.6is - SOLD
E36 M3 - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
uvels
where can i buy that adopters,can i use e38 Brembo callipers??
satan16v
300mm.de
E53 X5 4.6is - SOLD
E36 M3 - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
clarko74
The bolt spacing on the E38 brembos is different to the E32 540i ones.uvels wrote:where can i buy that adopters,can i use e38 Brembo callipers??
clarko74
LondonTom
What's the minimum size wheel you can run with this setup?
clarko74
These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
clarko74
LondonTom
Thanks Clarko.clarko74 wrote:These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
I use a 25mm master cylinder
Some pics of mine here - http://www.e30zone.net/modules.php?name ... &start=200
Lurch320i
Whos make of BBS reps are they? Any pics?
satan16v
Will this master cylinder be a straight swap? And improve the pedal feel, when running brembos up front and 540i rears?
http://www.ebay.co.uk/itm/301379572841
E53 X5 4.6is - SOLD
E36 M3 - SOLD
E53 X5 4.6is - SOLD
E36 M3 - SOLD
Kos
Demlotcrew had a set on his turdDanThe wrote:Whos make of BBS reps are they? Any pics?
www.pukardesigns.com
IG Pukar.Designs
IG Pukar.Designs
Lurch320i
Any manufacturers markings on them?
Jozi
If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
keri-WMS
Other way round, the larger m/c area creates lower line pressure for a given pedal force, the clamping force on the pads might be recovered at the front caliper with larger pistons (depending on the actual piston sizes) but the rears don't so you get a bias shift to the front.Jozi wrote:If you fit a bigger ms because of larger pistons and having to push more fluid does this mean the rears are more likely to lock up quicker because of more fluid being pushed down the lines?
bmw-mad
Do you have pictures?clarko74 wrote:These will work with 16" Hartges but I think that is about the only 16"wheel that will work with this setup.
As I Have the same setup
540 brakes and tt discs
the calliper wont clear my 16" alpina's
He said Hartges
I have the same problem, want to fit my Alpinas but the fronts need redesigning, new bracket/caliper and smaller disc. Rumour has it you need a 308mm disc to go under the Alpina wheel
Loads of pics in my thread, linked above
