The backs lower than it should be.
The sides are lower than the rest of it.
How do I reset my rear bumper and front bumper
jimbom30cab
- Tech 1 freak
if this is a facelift car then the runners the bumper sit on use eccentric holes I think , which can be adjusted to get a neat fit.
BROOMY
- busy saving Clifford
Where are the holes?
Yes it is a facelift.
The backs fine just the sides not. It's to low atm
jimbom30cab
- Tech 1 freak
take the bumper off and look at the slider brackets at the side, they can be adjusted
BROOMY
How you take the bumper off ?
jimbom30cab
- Tech 1 freak
For the rear, 2 large bolts - star shaped fittings - under the rear panel
BROOMY
The bit of plastic here?
http://i593.photobucket.com/albums/tt17 ... vqgrav.jpg
bumpygt
bmw9818
Torx T55 bolts or T45 or T50 one of the three, undo and pull off
Topblag
T55 Torx headed bolts. Soak them in wd40 or similar 24 hrs in advance, try and pull the bolt down as it's being loosened and use a 1/2 drive T55 socket, I broke three 3/8 drive T55s in a month.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
