davelarge
Sun Apr 27, 2014 12:02 am
Fitted my new smoked crosshair lights :)
Gavla
Sun Apr 27, 2014 9:01 am
Fitted a Bosch S5 096 Battery... :D
johnono
Sun Apr 27, 2014 6:18 pm
washed the car whilst listening to slipmatt on tunein,
so a flashback sunday :)
No pics of the car after sadly :(
also found out my central locking relay is dead, and i did the red black wire mod .
jas025
Sun Apr 27, 2014 6:53 pm
Went to take it for the MOT then this happened getting it out of the garage.
Took me an hour to sort it out by disconnecting the cable and rewrapping it round the cone but the cable has a number of kinks in it and it looks like it might go at some point. Missed my MOT slot :(
I rent the garage but organising someone to fix it will involve a bit of pissing about and having to put the car somewhere else while it gets done. I had a quick look at the web and it doesn't look overly complicated.
Are these simple to fix yourself? If so might have a go and deduct it from the rent.
hennabm
Sun Apr 27, 2014 7:00 pm
You can buy a new cable and fit it.
All that is needed is to take off the tension and then retension it afterwards.
IIRC there are a couple of allen keys to undo on the main cross bar which then allows you to engage a couple small bars to allow you to turn the spring round and round to retension the cables.
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Neilios
Sun Apr 27, 2014 9:30 pm
Mades quite a few plates. Welded some holes up! More to do in the next few weeks.
jas025
Sun Apr 27, 2014 10:02 pm
hennabm wrote:You can buy a new cable and fit it.
Cheers - I'll look for the make on the back of the door - have seen a few youtube clips that give some instruction.
Cypriotgeeza
Sun Apr 27, 2014 10:30 pm
Well not quite today (yesterday) but still 8)
Check my M30 build threads:
Mafisher
Mon Apr 28, 2014 11:31 pm
Fitted a new battery and bled the clutch! Next is new brakes all round and MOT :)
singlezero
Sat May 03, 2014 8:15 pm
It's been a long time coming, but finally in my mates garage today and let him work his magic...
(It's Brilliantrot by the way, my camera was struggling big tme with the gleam)
Gert_8
Sat May 03, 2014 9:49 pm
Was that done at mates rates? If not, how much did it cost, if you don't mind saying.
singlezero
Sat May 03, 2014 10:12 pm
I haven't got a figure I'm afraid.
my325ise
Sun May 04, 2014 2:18 pm
I fitted a new battery, fitted new 14"BBS (courtesy of T-coz), put an MOT on her, insured and Taxed her, gave a her a quick wash ( polish after it stops raining) and fixed the alarm and started installing some I.C.E... Bussy and Expensive week!!
my325ise
Sun May 04, 2014 2:49 pm
Maybe silly question but has my avatar taken over everyone else's page?! (Sizewise)
Gert_8
Sun May 04, 2014 4:00 pm
Yes!!
BHadley
Sun May 04, 2014 4:12 pm
Finally fitted a diff that's been knocking around, hopefully no milk float sounds now! had cleaned it up and painted it before fitting.
lubed all drop links and ARB bush mounts to aid removal to renew parts
my325ise
Mon May 05, 2014 2:28 am
Gert_8 wrote:Yes!!
My apologies.. I don't know how that happened! I've deleted it now!
'91 318i White
'90 325i SE Magenta
'98 106 GTi Silver
'10 330D Black
'14 LR Discovery HSE Drug Dealer Spec'd-Black.
lailt2.wordpress.com
biggill
Mon May 05, 2014 7:41 am
New shoes on the lady, original BBS RM split wheels along with a brand new wind screen chrome trim
hennabm
Thu May 08, 2014 5:05 pm
MOT and oil service at dealer and then fitted new fuel gauge.
However, the new gauge came with the face marked in litres instead of just 1/2 and F.
So a quick swop of the old face to the new unit and voila - a working fuel gauge again winkeye
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
bigbird76
Fri May 09, 2014 10:05 pm
Cleaned the car today and went for a quick spin
oomz1975
Fri May 09, 2014 11:42 pm
bigbird76 wrote:Cleaned the car today and went for a quick spin
Properly nice!
milescook
Sat May 17, 2014 10:34 pm
Fixed my ignition (push button), sprayed the roof with hammerite as there's bits of rust coming up :( , oh and not today but las week, fixed my passenger window after two years US...
Next month she's going back on the road. Hello trackdays! :D
Also please help the race budget by watching some videos :) https://www.youtube.com/cookracinguk
Motorhole
Sun May 18, 2014 9:59 am
Failed to fix it. Again.
Jona1971
Sun May 18, 2014 4:20 pm
Flushed radiator and fitted new Thermostat, topped up with blue coolant.
Gearbox next...
**BANNED**
Sun May 18, 2014 5:16 pm
hennabm wrote:MOT and oil service at dealer and then fitted new fuel gauge.
So the new gauge came with a European face?
I swapped a klm speedo to keep the litre fuel gauge in my touring! :o:
hennabm
Sat May 24, 2014 4:44 pm
It certainly did. :mad: I prefer the original of half and full rather than litres but I can see the attraction winkeye
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Craggy73
Sat May 24, 2014 4:53 pm
Fitted my new fuel tank. Put the diff, subframe and trailing arms back together ready to fit back on the car.
E30Worx
Mon May 26, 2014 6:21 pm
Tried to adjust tappets... had wrong feeler gauge... will try again in the week with the right tools.
Tried to fit new discs and pads... found no disc retaining screw in the drivers side front disc and couldn't get the calipers off so another failure.
Opened a big box containing fuel filler neck... looked at it a bit and then didn't even attempt.
Quite a bit for me to do this week including preparing the Mtech 2 kit ready for fitting and then breakdown of the entire car, fitting of new wing, ready for full respray.
Need to remove all interior including carpet. Carpet will be redyed black and leather is getting a full Lotus White makeover.
jonnyd
Tue May 27, 2014 2:39 pm
fitted new battery took her out for the first time in three months ran like a dream! happy days :)
im fat... that's how I roll
brian_s
Thu May 29, 2014 11:28 pm
Opened garage door, thought how good it would be to have it on the road, remembered I'm a lazy sod and shut the door again! :mad:
jimbom30cab
Tech 1 freak
Thu May 29, 2014 11:38 pm
bought this
davidt
Pompey Council 4 door deviant
Fri May 30, 2014 8:25 pm
Like the wheels Jim, will you be taking this to the Liphook show.
johnono
Fri May 30, 2014 8:51 pm
Sorted the central locking system out , at last i can lock the car
Turned out to be 2 motors and the conto, unit that needed to be changed. Now nice and smooth :)
Also changed the 4 o-rings on the head>coolant pipe on the s14 so no more water leak :)
And then took it for a drive for about 4 hours :)
Rich2388
Fri May 30, 2014 9:10 pm
Thats tasty looking jim. Where did you find it?
jimbom30cab
Tech 1 freak
Fri May 30, 2014 9:39 pm
Yes I will Dave, see you there
Rich, I gave it a mini resto last year , then sold it and I just bought it
