318iS
Revision as of 21:07, 16 July 2008 by Cook318is (talk | contribs)
The History
One of the last models of the E30 range to be added was the 318iS - a 2 door saloon. The 318iS was fitted with the M42 engine, the most up-date-engine fitted to any E30. It came with Sports Suspension (including rear Anti Roll Bars - ARBS), Sports Seats front vented discs; rear solid discs, power steering, electric windows, electric mirrors, de-chromed trim, M-tech steering wheel, leather gear knob and gaiter, front and rear spoilers and BMW sport seats. The 318iS did NOT come with a limited slip differential as standard but was a small case differential with a 4.10 ratio. The base model cost aproximately £14,750 when it was new. It started out life to beat the sports models that Volkswagon and other leading car manufacturers were producing (such as the golf GTI. Bmw set out to produce a sports BMW which would match/ beat the performance of the likes of the GTI with a 1800cc BMW. At this moment in time, the only E30 BMW capable of out-performing the GTI was the 325i. The M42 16V DOHC engine was developed which produced 136BHP and was one of the most technologically advanced engine for its time and is also one of the most fuel economic E30's achieving around the 33MPG with mixed driving . There were rumours that the 318iS actually out-performed BMWs own 325i, so they restricted the power so the sales of the more expensive 325i wasn't effected. But still with 126BHP/tonne, it still gives the 323i a good run for its money. In total, 41,234 318iS's were made which means that out of the full 2.2 million E30's, 1.86% of them were 318iS's. In 2001 the DVLA only had 1687 318iS's registered in the UK, the number has since thought to of fallen to around 900 which is making the 318iS becoming more valuable and sort after.
The Profile Gasket
Gasket(x1): 111 217 215 46
Bolt set(x1): 111 217 219 39
Gasket (x1): 111 412 478 49
Gasket (x1): 111 412 478 37
o-ring (x1): 121 417 272 20
Gasket (x1):116 117 344 90
Gasket (x1):116 1173 468 4
o-ring (x1):115 3172 121 8
Gasket (x1):115 3172 117 2
Gasket (x1): 183 017 119 69
Nut (x4): 183 017 377 74
The Timing Chain Tensioner
Tapping/ticking noise
Common upgrades
Useful websites
BMW ETK
BP's E30 318iS website
The M42 engine club
