M42
Revision as of 19:00, 16 July 2008 by Cook318is (talk | contribs)
Often referred to as an Engine crafted by God Himself.
In E30 form it's twin cam 16v 4cyl 1796cc engine. It is a aluminium alloy engine which has a relationship with the M1, M5 and M635CSi engines. The top of the rocker cover has a vapour/liquid separator which reduces oil consumption of the engine. When this engine first came out it was state of the art. The engine also has a duplex timing chain and a compression ratio of 10:1, which is similar to the duplex chain E30 M3 with a compression ratio of 10:5. The throttle body has two butterfly valves, a 35mm and 54mm valve. When you are lightly pressing the accelerator pedal, only the smaller valve opens but when you further depress your pedal the larger valve also opens. This enables the M42 engine to use less petrol when the car is on journeys which do not require constant change in speed. The inlet manifold is in two pieces, its design improves the low down torque of the engine. The engine also has hydraulic tappets which reduce the maintence of the engine. The engine produces 136BHP at 6000RPM and 127 ft lbs of torque at 4600RPM. The engine was then superceeded by the M44.
The E36 version adds a serpentine belt front pulley system and a different intake manifold. The M42 engine after 1992 was a 1900cc engine which produced 140BHP with 129 ft·lbf of torque and had a lowered redline of 6300RPM which is most commonly found in the E38 which has the M42 engine.
M42B18 Engine as fitted to an E30 318is:
Identifying traits and Points of interesting the above photo:
  • Individual coil packs
  • Twin-cam rocker cover
  • Twin-choke throttle (not-visible)
The Profile Gasket
Gasket(x1): 111 217 215 46
Bolt set(x1): 111 217 219 39
Gasket (x1): 111 412 478 49
Gasket (x1): 111 412 478 37
o-ring (x1): 121 417 272 20
Gasket (x1):116 117 344 90
Gasket (x1):116 1173 468 4
o-ring (x1):115 3172 121 8
Gasket (x1):115 3172 117 2
Gasket (x1): 183 017 119 69
Nut (x4): 183 017 377 74
The Timing Chain Tensioner
Tapping/ticking noise
Common upgrades
Aluminium flywheels are becoming a more popular upgrade for the M42 engines. Replacing the dual mass flywheel with an aluminium version reduces the strain on the engine drastically. Instead of the stock 27 lbs the aluminium flywheel only weighs abouut 9lbs. The reduced weight means that the engine can acelerate alot faster because there is less load on the engine. However because there is less weight it does mean that between gear changes the revs drop very quickly so it is possible to stall the engine between changes. But owners who have got aluminium flywheels do say that you can get used to the drop in the revs and it soon doesn't become a problem by either quickly changing gear or bliping the throttle between gears to sustain revs. Unfortunately the standard duel mass flywheel has springs in the flywheel (and not the clutch) which reduce/stop chatter created. The aluminium flywheels do not have this so a quiet chatter can be heard and the idle can some times be lumpy.
