Steering Rack Conversions
Parts
- New Rack
- Rack spacers (14mm)
Tools
- Ball-joint splitter
Which Rack?
Rack | Part Number | Turns
(lock to lock) |
Comments |
E30 | 4 | Standard power steering rack for all models | |
E36 | 3.4 | An adequate replacement for the E30. Nothing sporty, but certainly livelier than what the E30 left the factory with. | |
E36 M3 ('95) | 3.0 | Don't let the low lock-to-lock fool you. This rack is a variable speed unitm meaning it's ponderous in the middle and only rapid when it's close to full lock. In effect, this is the slowest of the E36 racks, and best avoided. | |
E36 M3 Evo ('96-) | 3.2 | Despite the lock-to-lock number, the E36 M3 rack isn't any faster than a standard E36 rack; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack. | |
E46 | 3.2 | A very good compromise between the older E36 rack and the wicked-sharp Z3. Cheap and plentiful too, but try getting a Clubsport rack if you can. | |
E46 Clubsport | 6 755 067 | 3 | The most popular choice these days, thanks to its speed and availability. Fitted to a range of E46s - look for the purple tag. |
Z3 | 3213 1094038
3213 1095577 |
Steering Linkage
E36 hybrid
Ready-made
Guibo Delete
Opel Corsa C
Rack
Pipes
Track Rods
If you're considering an E46 Clubman (purple tag) rack, keep in mind the stock inner rods have vented threads to equalise air pressure between left and right sides (boots) when the wheel is turned. To make this work, you need to use E46 inners and E36 outers. Alternatively, you can get crafty with a bench drill and modify a pair of E36 inners to have the same thread venting. E30 outers won't work here as they attach to the rack using a male thread. E46 inners and outers combined are (anecdotally), too wide to fit the E30.
Finishing
Complications
