Steering Rack Conversions
Revision as of 15:51, 27 April 2014 by Grrrmachine (talk | contribs)
For starters, newer rack are physically a little bit shorter. This means that you need a pair of small metal spacers so that you can bolt the new rack in exactly the same location as the original rack. The pikey solution is to use a pile of washers, but a sturdier solution is to fabricate your own spacers or buy them ready-made. They need to be 8mm (Z3) or 14mm (E36/E46) tall, at least 14mm wide, with an internal hole of 10mm diameter.
Parts
  • New Rack
  • Rack spacers (8mm for Z3, 14mm for E36/E46)
  • Inner and outer tie rods (complete set of either E30 or E36, but not E46)
  • Steering linkage (click here for more info)
  • New aluminium crush washers (14mm and 16mm)
Tools
  • Ball-joint splitter
  • 13mm, 15mm, 17mm, 19mm and 22mm sockets or spanners
  • A hammer and crowbar or suitable drift
Which Rack?
Rack Part Number Turns
(lock to lock)
Comments
E30 4 Standard power steering rack for all models
E36 3.4
E36 M3 ('95) 3.0 Don't let the low lock-to-lock fool you. This rack is a variable speed unitm meaning it's ponderous in the middle and only rapid when it's close to full lock. In effect, this is the slowest of the E36 racks, and best avoided.
E36 M3 Evo ('96-) 3.2 Despite the lock-to-lock number, the E36 M3 rack isn't any faster than a standard E36 rack; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack.
E46 3.2 While lock ratios are similar to others, the overall speed is noticeably slower. This isn't necessarily a bad thing though, as it doesn't feel twitchy at motorway speeds, unlike faster racks.
E46 Clubsport 6 755 067 3 The most popular choice these days, thanks to its speed and availability. Fitted to a range of E46s - look for the purple tag.
Z3 3213 1094038
3213 1095577
2.7 The fastest rack, and no need for a custom steering linkage, makes this the perfect rack. But most are now well over 20 years old, so finding a good one is increasingly difficult.
It is critical that you do not touch the adjustment nut between the inner and outer tie rod. If you do, you will have to go through the whole process of having your steering geometry (tracking) adjust once the installation is complete. Leave them completely alone for now.
Steering Linkage
E36 hybrid
Now, back to the hole in the disc. This is for the centering bush (similar to the nylon one on the E30 joint). If you look at the pinch bolt section you removed earlier, you should see a bronze bush in the centre. This is retained by some deformations (stakes ?) in the housing. With some careful drill work, the bush can be removed. It also helps if you cut through the side of the housing and open it up with a chisel. You need to make the hole in the centre of your new metal disc the same as the O/D of the bush. It needs to be a snug fit, and can be retained with some bearing securing solution (Loctite etc).
Ready-made
DanThe's steering linkage
Guibo Delete
Opel Corsa C
Rack
Rack mounted in the NON-PAS position
Spacers placed between top of rack and subframe
Pipes
Now is a good time to get your pipes connected. If you've ordered cusom pipes, you'll need to fit one hose to your PAS reservoir and the other to your PAS pump. Don't forget to use new crush washers to prevent future leaks.
Track Rods
Now you just need to get your rack connected to your wheels. You'll need a set of inner or outer track rods (tie rods in Americanese) to do this.
Finishing
Complications
318iS plastic under-tray modified for rack fitment.
Some 318iS owners have reported issues with steering linkage clearance when using the Z3 rack, so pay particular attention to which linkage you choose before starting. The plastic undertray on these cars can also interrupt with the fitment of the rack, so be prepared to cut away some of the plastic to make everything fit.
