Bushes
Revision as of 15:00, 25 April 2014 by Grrrmachine (talk | contribs)
| Suspension | |
The following list is all the parts you need to replace your Suspension bushes. Replacing them is not only a matter of safety; they'll also return the tight handling and comfortable ride that your E30 originally left the factory with. We've also included some sympathetic upgrades; the M3 options also fit normal road going E30's, even though this list is compiled with normal E30s in mind.
For an individual guide on removing and replacing each of these bushes, just click on the name of that bush.
Front
- Pair of E30 M3 eccentric top strut mounts (31331139484) - £94.41 each
- Studs x6 (31331092886) - £3.56 for 6
- Nuts x6 (31331092887) - £0.95 for 6
- Pair of E30 M3 eccentric lollipop bushes (31129061222) - £39 pair
- Drop Links (31351091764) - £54.03 pair
or
- Ford Mondeo estate Mk III (2000-20007) rear drop links - Lemforder 2581102 - £45 pair
- Pair of front ARB bushes - £18.55 pair
- 18mm - (31351127414)
- 20mm - (31351129139)
- 21mm (Cab) - (31351132355)
- ARB & Drop Link fasteners £5 extra per link
- Nuts (07119922856) & Bolts (07119901120) to suit the ARB mounts
- Nuts (07129964672) Washers (31111114348) to suit the Drop links
- N/S Track control arm (31121127725) - £92.81
- O/S Track control arm (31121127726) - £92.81
Rear
- Pair of E46 M3 Cab top shock mounts (33526779670) - £33.30 pair
- Pair of E30 rear beam bushes (33311129144) - £52.39 pair
- Set of Trailing arm bushes (33329061945) - £12.88 per side
or
- Eccentric Trailing arm bushes (33329058822) - £16.12 per side
- Pair of ARB bushes £5.68 pair
- 12mm (33551129677)
- 13.5mm (33551131290)
- 14.5mm (33551130349)
- Pair of ARB drop links (33551126932) - £23.50 pair
- ARB & Drop Link Fasteners Extra £8 per side
- Nuts (07129946400) & Bolts (07119912501) to suit the Drop links
- Nuts (07129900047) & Bolts (33321136406) to suit the Trailing arm
- Bolt with washer (07119915066) to suit the ARB mounts
- 3.0 / Z3M Differential mounting bush (33172228425) - £21.34
