Limited Slip Differential
Case sizes
Ratios
- 3.15 - M3
- 3.64 - prefacelft 325i
- 3.73 - facelift 325i
- 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport
- 4.27 -
- 4.44 -
Identification
To identify an LSD one can first check for the presence of the tag on the rear casing. The ratio on this will be prefixed with an S for LSDs.
Oil
