Bushes
Revision as of 20:37, 16 February 2013 by Grrrmachine (talk | contribs)
(Originally Submitted on the E30 Zone by OBs)
Heres a list of what you might need. The M3 options do fit normal road going E30's, it is for the non 'M' car that I have put this list together.
The Wiki has guides to removing and replacing many of these bushes. To learn more, just click on the name of that bush.
Front
  • Pair of E30 M3 eccentric top strut mounts (31331139484) - £94.41 each
    • Studs x6 (31331092886) - £3.56 for 6
    • Nuts x6 (31331092887) - £0.95 for 6
  • Drop Links (31351091764) - £54.03 pair
Superflex sell a set of replacement bushes @ circa £20
  • Pair of front ARB bushes - £18.55 pair
    • 18mm - (31351127414)
    • 20mm - (31351129139)
    • 21mm (Cab) - (31351132355)
  • ARB & Drop Link fasteners £5 extra per link
    • Nuts (07119922856) & Bolts (07119901120) to suit the ARB mounts
    • Nuts (07129964672) Washers (31111114348) to suit the Drop links
  • N/S Track control arm (31121127725) - £92.81
  • O/S Track control arm (31121127726) - £92.81
Rear
or
  • Eccentric Trailing arm bushes (33329058822) - £16.12 per side
  • Pair of ARB bushes £5.68 pair
    • 12mm (33551129677)
    • 13.5mm (33551131290)
    • 14.5mm (33551130349)
  • ARB & Drop Link Fasteners Extra £8 per side
    • Nuts (07129946400) & Bolts (07119912501) to suit the Drop links
    • Nuts (07129900047) & Bolts (33321136406) to suit the Trailing arm
    • Bolt with washer (07119915066) to suit the ARB mounts
  • 3.0 / Z3M Differential mounting bush (33172228425) - £21.34
