E28
Revision as of 23:09, 15 February 2013 by Grrrmachine (talk | contribs) (New page: 350px|right The E28 is the third edition of BMW's 5-series. It replaced the E12 in 1981, and was replaced by the E34 in 1988. It is an established and appr...)
The E28 is the third edition of BMW's 5-series. It replaced the E12 in 1981, and was replaced by the E34 in 1988. It is an established and appreciating classic, thanks primarily to its iconic shark-nosed front end which it shares with the E21.
The E28 is particularly famous for being the chassis for the very first M5. By combining the saloon chassis with the engine from the phenomenal M1, BMW were able to produce a 3.5-litre monster with up to 282hp. And with only 2,191 units ever built, the E28 M5 is a very rare and very desirable beast.
Compatible Parts
Engines
Main article: Engine Swaps
NOTE: The engine mounts for the E28 M5 are desirable for the M50/M52 engine swap.
The radiator fitted to the largest M30 engine, the 535i, is considered the best for those contemplating an M50/M52 engine swap.
Small case differentials were fitted to the E28, but both the back plate and output flanges need to be swapped to E30 equivalents.
