Engine Swap - M42
Identification
M44 crank sensor location:
M42 crank sensor location:
Parts List
You need:
- M42 engine
- E30 M42 engine loom and ECU (will work with E36 engines also, saves having to adapt E36 looms and causing issues!)
- E30 M40 or M42 engine mounts
- Coil packs and HT leads or COP conversion
- M42 exhaust manifold
- 318iS exhaust system
- M42 coolant hoses
- M42 AFM to TB boot
- Getrag 240 gearbox
- 318iS propshaft
- E30-specific oil sump from an M40 or M42 engine. An M10 sump will not fit.
- Radiator upper and lower mounts are different and need to be fabricated
- Engine subframe/mounts are about 10mm too wide for the M42 engine legs
- Coil pack needs to have a mount made and attached to hold in place
- M42 engine requires a fuel pump in the tank, or in-line AND a fuel return pipe to be added. On many cars the wiring loom does cater for an in-tank fuel pump
- On carburretted M10 engines the fuel tank will need replacing to provide an in-tank swirl pot.
- Air filter needs a bracket / mount made
- Wiring loom requires a swap (2 wires, oil and temp need swapping) and there is a LIVE off the engine loom the goes directly into and EARTH on the multi plug!
- M40 or M42 instrument cluster. This is down to an issue with the temperature gauge.
Coil packs
Single mass:
Ancillaries
