Interior
Dashboard
Instruments
Main article: Instruments
Controls
Vents
Heating
Main article: Heating
Aircon
Main article: Aircon
Upholstery
Main article: Upholstery
Seats
Front Seats
Also available are Heated Seats, which provide a gentle warming sensation for your posterior when needed. These are controlled by switches mounted to the tunnel.
Rear Bench
Door Cards
Carpet
E30 Carpet
Headlining
Maintenance
Loose Seat Back
Backrest Not Locking
