Interior
Dashboard
Instruments
Main article: Instruments
Controls
Vents
Heating
Main article: Heating
Aircon
Main article: Aircon
Upholstery
Main article: Upholstery
Seats
Front Seats
Rear Bench
Door Cards
Carpet
E30 Carpet
Headlining
Maintenance
Loose Seat Back
Backrest Not Locking
