Interior
Dashboard
Instruments
Main article: Instruments
Controls
Vents
Upholstery
Main article: Upholstery
Seats
Front Seats
Seat Belts
Rear Bench
Rear Seat Belts
Door Cards
Carpet
E30 Carpet
Headlining
Maintenance
Loose Seat Back
Backrest Not Locking
