Engines Troubleshoot
Troubleshoot
START | ||||||||
test bulb on coil | bridge wire to coil | green wire | ||||||
Does it glow? | → | Immobiliser? | → | OBC? | → | Check for 12V at ECU | ||
Does the engine crank? | → | → | → | Does it try to start? | → | Pull out Fuse 11 | ||
Does the battery have 12V? | → | charge battery | ↓ | Does it try to start? | → | ↓ | ||
↓ | ← | Does the ICV buzz
with ignition on? |
↓ | ↓ | ↓ | Test Blue Temp Sensor | ↓ | ||||
Diagnostic Plug Start | Bridge the DME Relay | → | Does the fuel pump
run when cranking? |
↓ | DME Relay | Check Fuse 11 | ↓ | ↓ | ||||
↓ | Fuel Pump Relay | ← | Bridge the Fuel Pump Relay | Fuel Pump | ↓ | ↓ | ||
Does the engine crank? | → | Ignition Switch | Connect bulb across Fuel Pump pins | → | Does it glow? | ↓ | ↓ | |
Starter Motor | Test CPS | ← | ← | ← | Check for spark | ← | ↓ | |
Replace ECU | Check for air leaks | ← | ← |
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
12V At ECU
Ignition Switch
First thing to do is to check you have a good +12v signal coming out of the ignition switch when you try to start the engine. Connect your 12V 5W test light between ground and the yellow/black wire at the socket where the ignition switch plugs into the main loom at the steering column. If you don't get a good supply from there (test light does not light up brightly), your switch is most likely faulty.
If you do get a good bright light, get in behind the glove box and find the plug where you can split the black/yellow wire (this is where the auto loom plugs in- its purpose is to isolate the starter if not in park or neutral). Check that the connection is good and then connect the test light on the motor side of the plug and check that it lights brightly when attempting to start.
Hopefully now you will have found your fault as the only bit left is the wire between C101 and the starter solenoid, and this is unlikely to be faulty given the fact that the car swings over readily from the diagnostic socket. But check it anyway, clean the terminal on the starter and hopefully it will be good to go!
Check for Spark
