Engines Troubleshoot
Revision as of 07:30, 17 February 2012 by Grrrmachine (talk | contribs)
Troubleshoot
START
test bulb on coil bridge wire to coil green wire
Does it glow? Immobiliser? OBC? Check for 12V at ECU
Does the engine crank? Does it try to start? Pull out Fuse 11
Does the battery have 12V? charge battery Does it try to start?
Does the ICV buzz
with ignition on?
Test Blue Temp Sensor
Diagnostic Plug Start Bridge the DME Relay Does the fuel pump
run when cranking?
DME Relay Check Fuse 11
Fuel Pump Relay Bridge the Fuel Pump Relay Fuel Pump
Does the engine crank? Ignition Switch Connect bulb across Fuel Pump pins Does it glow?
Starter Motor Test CPS Check for spark
Check for air leaks
Solutions
Test Bulb On Coil
Bridge Wire To Coil
Green Wire
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
12V At ECU
Check for Spark
If you're not getting a spark from the coil, then you need to test the coil or replace it with a known working one. If you still don't see a spark, then you need to investigate the wiring linking the coil to the battery and to earth.
