Engines Troubleshoot
Revision as of 22:59, 16 February 2012 by Grrrmachine (talk | contribs)
Troubleshoot
START
test bulb on coil bridge wire to coil green wire
Does it glow? Immobiliser? OBC? Check for 12V at ECU
Does the engine crank? Does it try to start? Pull out Fuse 11
Does the battery have 12V? charge battery Does it try to start?
Does the ICV buzz
with ignition on?
Test Blue Temp Sensor
Diagnostic Plug Start Bridge the DME Relay Does the fuel pump
run when cranking?
DME Relay Check Fuse 11
Fuel Pump Relay Bridge the Fuel Pump Relay Fuel Pump
Does the engine crank? Ignition Switch Connect bulb across Fuel Pump pins Does it glow?
Starter Motor Test CPS Check for spark
Check for air leaks
Solutions
Test Bulb On Coil
This is the initial test performed on all E30 engines. It involves connecting a test bulb between pin 15 (green wire) of the ignition coil and earth, to confirm the presence of 12V. Using a multimeter is not enough; you need at least a 12V 5W bulb to get a meaningful reading. An indicator lamp with a length of cable is ideal.
Bridge Wire To Coil
If power isn't being delivered to the coil, we need to confirm that the rest of the system works fine. We can do this by supplying power directly to the coil from the battery. To do so, connect a wire to pin 15 (green wire) of the ignition coil, and then connect the other end to the [[Battery|battery + terminal. This should immediately power up the car circuits, making the battery light on the dash cluster, and the ICV should start buzzing.
Green Wire
The Ignition circuits are powered by a single green wire that runs through the interior of the car from the ignition switch to the ignition coil. This wire can be broken, damaged, interrupted by an immobiliser or the OBC, or simply not powered due to a broken ignition. Whatever the cause, we need to test it.
To start with, disconnect the [[C101] plug, and use a multimeter to check for continuity between the ignition coil pin 15 and pin 7 (Motronic) or pin 8 (Jetronic) on the engine side of the engine loom. If you don't have continuity, the wire is broken somewhere in the engine bay.
Charge Battery
Bridge DME Relay
Bridge Fuel Pump Relay
Bulb Across Fuel Pump
12V At ECU
Check for Spark
If you're not getting a spark from the coil, then you need to test the coil or replace it with a known working one. If you still don't see a spark, then you need to investigate the wiring linking the coil to the battery and to earth.
