Revision as of 17:14, 29 January 2012 by Grrrmachine (talk | contribs)
Everything that connects the Wheels to the Bodywork of your E30 is the Suspension. This arrangement of springs, shocks and arms is responsible for keeping the rubber of your tyres on the road at all times; without it, you'd be bounced around a pinball.
Sturdier components were fitted to the six-cylinder models (M20 and M21 engines), incorporating bigger front struts and sturdier springs to carry the heavier weights. The same struts were fitted to all Touring and Cabriolet models, as well as different rear springs to carry the heavier bodies of those cars.
Front
Front suspension layout
The front suspension is comprised of two struts which each incorporate a shock absorber and a spring
Struts
Shocks
Springs
Wheel Hub
Subframe
Wishbones
Lollipops
Ball Joints
Strut Brace
Rear
Rear suspension layout
Rear Beam
Trailing Arms
Rear Shocks
Rear Springs
Rear Anti-Roll Bar
Rear Bushes
Inner Tyre Wear
Maintenance
Bush Renovation
