Revision as of 19:22, 23 October 2011 by Grrrmachine (talk | contribs)
Brake Pedal
Brake Light Switch
Brake Servo
Intake Valve
Master Cylinder
Reservoir
Pressure Valve
Brake Fluid
DOT 4 braking fluid should be used, although DOT 5.1 non-silicon is an acceptable alternative. It is essential to use non-silicon fluids as it can cause failure of the rubber seals in the calipers.
Brake Lines
Brake Hoses
Calipers
Discs
Pads
Pad Wear Sensor
Drums
Cylinders
Shoes
Handbrake
Rear disc handbrake setup
With rear discs, the bottom of the shoes are pushed by the handbrake and the top are pushed by a static adjuster. If you only adjust the handbrake at the lever then you don't get full shoe contact and you'll get odd wear and a reduced efficiency handbrake.
You adjust this through a wheel stud hole with a small flathead screwdriver. Rotate the disc until a hole is at the 12 o'clock position and look in with a torch. Adjust the top until the brake locks up, and then back it off a bit.
Then put the wheel back on, and adjust the tension at the handbrake lever so that the wheel is locked at ~5 clicks of the lever. ...or just whetever feels right. Each side is adjusted independently.
ABS
Main article: ABS
For ABS vehicles, the rear ports of the Master Cylinder are blanked off.
Bleeding
Replacing Pads and Discs
The first step is to lever the pads and the caliper away from the disc. do this by inserting a screwdriver behind the pad (there should be a small lip on the pad you can get leverage on) and pulling the s/driver towards you.
Replacing Fluid
Replacing Rear Shoes
Rebuilding Calipers
Soft Brakes
Air
Pulling
Squealing
Stuck Brakes
Main article: Brake Upgrades
