Intake
Revision as of 12:33, 20 October 2011 by Grrrmachine (talk | contribs)
Air Filter
AFM
Rubber Boot
If you find that your ICV no longer fits your Rubber Boot, unfortunately this is due to the two types of ICV available. The solution is either to change the Rubber Boot, or change the ICV.
Throttle Body
If you think the Throttle Stop has been tampered with, or you have stripped and rebuilt your throttle body, then the closing point can be reset using a XX feeler gauge between the door and the bore of the throttle body. However, to accurately set the throttle stop requires the services of an exhaust gas analyser.
Throttle Position Switch
Removing and cleaning a TPS is easy, and should be cleaned with Contact Cleaner. It can also be good to drill a 1- or 2mm hole right into the middle of the TPS as well, which will allow oil from the Throttle Body to drain out without blocking the TPS in future.
ICV
The Idle Control Valve, or ICV, can be thought of as an electric door; it spins around at a certain rate, blocking and opening the passage so that only a specific flow of air can pass through it. It activates as soon as the ignition circuits are turned on, and should make a light buzzing noise.
Intake Manifold
Lambda
Turbo
Air Leaks
The next item is a small rubber plug on the back throttle body, which can only be accessed with the throttle body removed. This little plug blocks off a port designed to feed the carbon canister, which is rarely fitted to UK cars. Over time, this rubber plug breaks down, creating a massive leak.
Idling
The first cause of idle problems, especially a high idle, is likely to lie with the fuelling of the car, especially controlled by the blue plug.
Stalling
K&N Filter
Replacing the existing air filter with a bolt-on aftermarket one is a cheap and popular modification to E30 engines, but Zone opinion is very heavily weighted against them. The standard BMW filter is more than adequate for standard engines, and replacement filters will only be needed after severe modifications to the rest of the engine.
Throttle Bodies
MAF
