Fuel
Revision as of 19:56, 13 October 2011 by Grrrmachine (talk | contribs)
To keep your E30 moving, it needs fuel. Since the majority of E30s use petrol injection engines, "Fuel" here is a synonym for "Petrol".
For Diesel engines, jump to the Diesel section of this page.
Fuel Tank
Filler Pipe
Fuel Pump
Fuel Level Senders
Fuel Filter
Fuel Lines
Fuel Hoses
Fuel Rail
Injectors
The injectors are the exit point of the fuelling system. They are electrically-operated solenoids which, when activated, squirt fuel at such high pressures that it atomises into a fine mist, which is the most efficient form for it to burn. The injectors are considered one of the most important components in a well-running engine, and one of the best ways to get more power from your old engine is to get the injectors back into good working order by cleaning them, and fitting new pintle caps if necessary.
Fuel Pressure Regulator
Carbon Canister
Controlling
The injection system is the main function of the ECU, be it L-Jetronic or Motronic. The ECU reads data on the engine from the Crank Position Sensor, and activates the fuel pump via the Fuel Pump Relay. This provides power directly to the fuel pump through Fuse 11.
Fuel Pump Relay
No Fuel to Engine
The test to see if any fuel is reaching your engine is to detatch one of the hoses in the engine bay, put the end into a container (such as a water bottle) and then crank the engine. If fuel gets to the bottle, you have fuel. To do this:
  • Depressurise the system by removing Fuse 11 and cranking the engine
  • Undo the jubilee clip to the nearest accesible hose, pull the hose off and put the end into a securely-placed container
  • Replace Fuse 11
  • Check the bottle
  • Check Fuse 11
Fuel Smell (Inside)
Fuel Smell (Outside)
Fuel Leak
Fuel Leaks
Leak Location Cause Solution
Rich Running
Flooding
Cold Start
The E30 fuel system is designed to be constantly under pressure, which means that it fuel should be pumped straight into the engine the moment the key is turned. If this doesn't seem to be happening, it's very likely that the system is losing pressure, which indicates a leak. Check all of your lines and hoses, especially with the engine running, and look for a mist or spray. Fix any leak immediately.
Hot Start
None at this time.
Diesel
The 324d and 324td were Diesel versions of the E30, and employed an indirect injection fuelling system.
Diesel Components
While the main components of this system are the same as petrol engines, a diesel system employs a pump which also functions as a multiple injector. This combined unit is capable of injecting diesel into each cylinder in turn at pressures far beyond that of a standard petrol engine. It is located under the intake manifold. Even though the in-tank pump is no longer present, the same 55L fuel tank is used, albeit with a different fuel level sender.
Diesel Controlling
The diesel system was available in two flavours. Then earlier system fitted to the 324d was cable-driven and directly controlled by the accelerator pedal. This was replaced by a later fly-by-wire system for the 324td that read data from a throttle pedal sensor. Both of these systems employed a belt-driven pump with a DDE ECU to control injector cycling, with the later system employing a second DDE to read the throttle data. The pumps on these two systems are clearly different, and not interchangeable.
Diesel Common Problems
Diesel Cold Start
Because diesels do not use spark plugs to ignite the fuel, but instead use immense pressure to create heat for diesel detonation, the fuel needs to be warmed before the engine can start from cold. This employs the use of glow plugs, controlled by a pre-heating control unit. To activate the glow plugs, the ignition key is turned to IGN but the engine is not cranked. The key is held in this position until the glow plug light in the dash cluster goes out.
If your diesel is reluctant to start in the morning, cycling the glow plugs twice (warming, then shutting off the circuit, then repeating) will ensure that the plugs warm to their maximum heat. If this starts your car, it is a sign that your glow plugs are ageing and need replacement. There are six of them, located in the head under the inlet manifold.
Diesel Cutting Out
Because of the complexity of the diesel fuel pump, most engine issues are connected here. The simplest cause of the problem is an ageing or corroded fuel solenoid, or the connections to it.
