318iS
Technical
Engine
- Main article: M42
Fuel System
Test pressure: 3 Bar/43psi
Ejection angle: 30 deg
Ignition
Motronic : Bosch DME 0-261-200-175 Software version 1.7 (US details)
Spark plugs : 16mm 3 electrode NGK BKR6EK or Bosch F7LDCR. The Champion RC8DMC can be used too. Note a 4 electrode platinum plug has
Plug gap : As specified above, they are unadjustable (pregapped) otherwise 0.027"
Idle Speed : 850rpm
Techincal info
Front settings : Castor 8½º ± ½, Camber -2/3rdsº ± ½, Toe-in 0.028" ± 0.024, Steering axis inclination 13 5/6thsº ± ½
Rear settings : Camber -2º ± ½, Toe-in 0.080" ± 0.031
Tyres : 195/65/V14 205/55/V15
Wheels : 14"x6", 14"x6.5", 15"x7", 4x100 cts mm bolt holes, centre hubs are 57mm, wheel bore 57.1mm
Wheel offsets :
6" rim width: 35mm offset
6½" rim width: 30mm offset
7" rim width: 25mm offset
Braking
Rear pads: I use Pagid 0307NA
Minimum pad thickness = 2mm
- Main article: Common M42 Problems page
As favoured as the M42 engine is, it's not perfect, and has its own quirks that show up regularly. Aside from the lumpy idle and fuel smell that can plague all E30s, the 318iS is especially prone to ticking and tapping noises, profile gasket failure and problems with the timing chain tensioner.
Common upgrades
Performance
Useful websites
General Info
Wheel base = 101.2"
