Instruments
Revision as of 04:52, 7 October 2011 by Grrrmachine (talk | contribs)
Dash Cluster
SI Batteries
if the SI batteries have leaked, the entire circuit board will need to be replaced.
Coding Plug
Individual Gauges
Speedometer
The Speedometer is a very quick way of seeing which engine is fitted to your car.
Odometer
Fuel Gauge
The same fuel gauge was fitted to all models of E30, and features a simple swing gauge as well as an amber warning lamp, which illuminates when the tank reaches its last 8 litres.
Temp Gauge
Tachometer
Econometer
Dash Lights
Check Light
Brake Lights
Indicators
Main article: Indicators
Inspection Lights
OBC
Main article: 13-button OBC
Check Panel
Above the rear view mirror of M20 models was a check panel, which warned the driver of any problems with lights and fluids.
Extra Gauges
VDO Gauges
Alpina
