E30
Models
Base models
316
318
320
325
324d
Sports
318iS
325iS
M3
Variants
Alpina
Hartge
Technical
Engines
- Main article: Engines
- Main article: Gearbox
- Main article: Differential
- Main article: Brakes
- Main article: Suspension
Steering
- Main article: Steering
Body Styles and Fittings
- Main article: Bodywork
Electrical
- Main article: Electrics
