Limited Slip Differential
Revision as of 17:14, 26 July 2009 by 91.149.179.60 (talk)
Generally Limited Slip Differentials are referred to as a Slipper or as an LSD. This contrasts to the normal differential fitted that is known as an Open Diff.
E30s with LSD as standard
Case sizes
E30 LSD Ratios
  • 3.15 - M3
  • 3.64 - prefacelft 325i
  • 3.73 - facelift 325i
  • 3.91 - facelift 325i touring, cabrio, 325i with getrag 260 sport
  • 4.10 - found optionally on UK spec 318i/318iS 2/4dr in Small Case, and on all US M3 models in Medium Case.
  • 4.27 -
  • 4.44 -
What these numbers mean
What oil to use for your LSD
External Links
