318iS
Revision as of 22:43, 17 November 2010 by Itemewuta (talk | contribs)
>318IS magazine spread
The History.
The Profile Gasket
Gasket(x1): 111 217 215 46
Bolt set(x1): 111 217 219 39
Gasket (x1): 111 412 478 49
Gasket (x1): 111 412 478 37
o-ring (x1): 121 417 272 20
Gasket (x1):116 117 344 90
Gasket (x1):116 1173 468 4
o-ring (x1):115 3172 121 8
Gasket (x1):115 3172 117 2
Gasket (x1): 183 017 119 69
Nut (x4): 183 017 377 74
The Timing Chain Tensioner
Tapping/ticking noise
Common upgrades
Useful websites
BMW ETK
BP's E30 318iS website
The M42 engine club
**Part numbers were correct at time of typing, some may have been superceeded my a newer part. You use this information at your own risk - contact your local dealer to double check quantities/part numbers** Engine
Designation : M42b18 Unmodded and Modded
Unmodded and Modded2
Dimensions (nominal) : 84mm/3.31" bore x 3.19" stroke
Displacement : 1796 cc
Camshaft : Duration: inlet 252 exhaust 252 Lift: inlet 10.2 exhaust 10.2
Lobe height: 1.8755-1.8803"
Con-rods : Max. weight variance without bearing shells: 4g/14oz split equally between big and small ends
Crankshaft : End play: 0.0031-0.0064"
Thrust on cylinder 4
Cylinders : Max. ovality: 0.01mm/0.0004"
Max. taper: 0.01mm/0.0004"
Cylinder head : Height = 140mm/5.512"; minimum height = 139.55mm/5.494"
Firing order : 1-3-4-2
Fuel Pressure : 43 psi
Oil pressure : 1.3-2.0 Bar/18 psi @ idle, 4.0-4.3 Bar/57-62 psi at 6250rpm
Oil Filter : Hengst E88H D24 in-bowl type
Oil Type : I would recommend a 5W40, 5W50 or 10W50 fully synthetic (the text book says 15W50) as the tappets seem to prefer a lower viscosity oil
Output : 134 (cat) -136 (non-cat) bhp @ 6000rpm; 127 ft-lb @ 4600 rpm
Pistons : Clearance: 0.0004-0.0016"
Piston rings : Gap: Top & bottom compression rings = 0.0080-0.0160" ; oil ring = 0.0080-0.0180"
Compression pressures : 10-11bar (143-156psi):
Torques : Big ends: Step 1 = 23Nm/17 ft-lbs, Step 2 = +70 degrees
Flywheel: 82-94 ft-lbs
Valves : Seat angle: 45 degrees
Valve clearance : None, automatically compensated by hydraulic tappets
Fuel System
Test pressure: 3 Bar/43psi
Ejection angle: 30 deg
Ignition
Motronic : Bosch DME 0-261-200-175 Software version 1.7 (US details)
Spark plugs : 16mm 3 electrode NGK BKR6EK or Bosch F7LDCR. The Champion RC8DMC can be used too. Note a 4 electrode platinum plug has
Plug gap : As specified above, they are unadjustable (pregapped) otherwise 0.027"
Idle Speed : 850rpm
Chassis Front suspension Rear suspension
Techincal info
Front settings : Castor 8½º ± ½, Camber -2/3rdsº ± ½, Toe-in 0.028" ± 0.024, Steering axis inclination 13 5/6thsº ± ½
Rear settings : Camber -2º ± ½, Toe-in 0.080" ± 0.031
Tyres : 195/65/V14 205/55/V15
Wheels : 14"x6", 14"x6.5", 15"x7", 4x100 cts mm bolt holes, centre hubs are 57mm, wheel bore 57.1mm
Wheel offsets :
6" rim width: 35mm offset
6½" rim width: 30mm offset
7" rim width: 25mm offset
Braking
Front : ATE or Hoeflinger Ventilated disc, 10.24" diameter Rear : ATE or Hoeflinger Soild disc, 10.16" diameter Handbrake: Drum, integral with rear disc, manually adjusted internally at rear of lever. Shoes usually last the lifetime of the car. Calipers: ATE or Girling Master cylinder: ATE Recommended Fluid: DOT 4 - BMW recommend changing the fluid every 24 months. I would recommend changing it before and after a track session also.
Rear pads: I use Pagid 0307NA
Minimum pad thickness = 2mm
Lubrication Engine : Fully or semi-synthetic, 15W-50 depending on environmental temperatures (although I would recommend a 5W40, 5W50 or 10W50 fully sythetic) - 4.5 litres, 5.26 qrts Engine oil filter : Hengst E88H D24, in bowl type Gearbox : 1.2 litres, 2.5 pts BMW Mobile traditions CD-Rom designates DEXRON II automatic transmission fluid Differential : Castrol SAF-X0 75W-90 or Castrol Synthrax or Hypoid 90 (for open diffs). Castrol SAF-XLS for Limited Slip Diffs. Also see Castrol's website.
Performance I have made two quicktime videos showing the car acceleration, one showing the 0-60mph (~9.1 seconds) and 0-100mph (~26.2 seconds).
Performance stats chart
  • Figures for E30 taken with a crew of two and a full fuel tank.
Max BHP : 136bhp @ 6000rpm Max Torque : 127 ft-lbs @ 4600rpm BHP/Litre : 75.6 Official MPG (Urban) : 26.9 Official MPG @ 56mph : 47.9 Official MPG @ 75mph : 37.2 30 to 50 mph in 4th/5th : 8.5/12.8 secs 40 to 60 mph in 4th/5th : 9.2/13.2 secs 50 to 70 mph in 4th/5th : 9.6/13.4 secs 60 to 80 mph in 4th/5th : 9.0/14.6 secs 70 to 90 mph in 4th/5th : 9.7/17.3 secs
General Info
Wheel base = 101.2"
>=Under Construction! Please Visit Reserve Page. Page Will Be Available Shortly=
CLICK HERE
