Doors
Doors
Dimensions
Front Doors
Saloon/Touring Coupe
Length Image Length Image
B 990mm B mm
C 540mm C mm
D 1020mm D 1020mm
E 590mm E 590mm
Rear Doors
Saloon Touring
B mm B 930mm
C mm C 720mm
D 1020mm D 1020mm
E 590mm E 590mm
Windows
Main article: Windows
Facelift electric window mechanism
Wing Mirrors
If you find your glass is cracked or faded, learn more about replacing the wing mirror glass.
Locks
Main article: Locks
Main article: Central Locking
Electrics
  • Door locks
  • Door lock heater (if fitted)
  • Wing mirrors
  • Electric windows (if fitted)
Trim
Rust
Sticky Windows
Electric Windows not working
If none of your electric windows work with the front doors open, check fuse 28. If your electric windows only work with the door open, but not with the ignition on, then check fuse 17. If they still don't work, pull out relay K5 and link together pins 30 and 87 of its socket with a short piece of wire. If this makes them work the relay is either faulty, or there is a problem with the unloader circuit, associated (on facelift cars) with the green/black wire to the starter motor. In this latter case, you will probably have a non-working heater blower and non-working door mirrors as well. A known symptom is that the green/black wire terminal on the starter motor works loose; tighten it up again by hand and refit the wire, and your windows should now work.
