Steering Rack Conversions
For starters, newer rack are physically a little bit shorter. This means that you need a pair of small metal spacers so that you can bolt the new rack in exactly the same location as the original rack. The pikey solution is to use a pile of washers, but a sturdier solution is to fabricate your own spacers or buy them ready-made. They need to be 8mm (Z3) or 14mm (E36/E46) tall, at least 14mm wide, with an internal hole of 10mm diameter.
Parts
- New Rack
- Rack spacers (8mm for Z3, 14mm for E36/E46)
Tools
- Ball-joint splitter
Which Rack?
| Rack | Part Number | Turns
(lock to lock) |
Comments |
| E36 | 3.4 | ||
| E36 M3 | 3.2 | Despite the lower lock-to-lock number, the E36 M3 rack isn't any faster; it simply has massive locking plates fitted to it that limit the overall rack movements. Remove these plates, and it's a standard E36 rack. | |
| E46 | 3.2 | While lock ratios are similar to others, the overall speed is noticeably slower. This isn't necessarily a bad thing though, as it doesn't feel twitchy at motorway speeds, unlike faster racks. | |
| Z3 | 3213 1094038
3213 1095577 |
It is critical that you do not touch the adjustment nut between the inner and outer tie rod. If you do, you will have to go through the whole process of having your steering geometry (tracking) adjust once the installation is complete. Leave them completely alone for now.
Steering Linkage
E36 hybrid
Ready-made
Guibo Delete
Opel Corsa C
Rack
Pipes
Now is a good time to get your pipes connected. If you've ordered cusom pipes, you'll need to fit one hose to your PAS reservoir and the other to your PAS pump. Don't forget to use new crush washers to prevent future leaks.
Track Rods
Now you just need to get your rack connected to your wheels. You'll need a set of inner or outer track rods (tie rods in Americanese) to do this.
Finishing
Complications
Some 318iS owners have reported issues with steering linkage clearance when using the Z3 rack, so pay particular attention to which linkage you choose before starting. The plastic undertray on these cars can also interrupt with the fitment of the rack, so be prepared to cut away some of the plastic to make everything fit.
