Interior
Revision as of 07:22, 16 March 2013 by Grrrmachine (talk | contribs)
Dashboard
Instruments
Main article: Instruments
Controls
Vents
Heating
Main article: Heating
Aircon
Main article: Aircon
Upholstery
Main article: Upholstery
The upholstered items of your E30 were chosen by the original purchaser, based on recommendations by the dealer. The selection affected the colour of the seats and door cards. Learn more about upholstery options.
Seats
Main article: Seats
While the types of upholstery did change year on year, the physical shape did not, meaning seats are compatible for each model before and after the facelift.
Each E30 is equipped with two front seats and a rear bench. All front seats are interchangeable, although 4-door and Touring seats do not feature the tilt mechanism of 2-door and Cabriolet seats. However, the rear bench is specific to each model.
Learn more about Seats.
Door Cards
Door cards were available in cloth, vinyl or leather. Door cars are as specific to the vehicle as the doors themselves; therefore they share the same compatibility.
Unfortunately, it is not possible to disassemble a door card. For that reason, repairing any damage to the upholstered section of a door card requires a full retrim of the card. If you need to take your door cards off, here's how.
Carpet
E30 Carpet
All E30 carpets are a two-piece component. The main part extends from the bulkhead to the rear passenger footwells, and is identical across all models. Don't be conned by shady traders; there's no such thing as a "sport" carpet. The rear section sits vertically and tucks under the rear seat, and varies between model types. This accommodates the different seat cushion shapes across the model range.
Two materials were used for E30 carpets. M20-engine models, Cabriolets and Tourings have a velour-type material, which can be dyed if needed. The lower 4-cylinder models have a nylon hard-wearing carpet which cannot be dyed.
Headlining
Loose Seat Back
Backrest Not Locking
Wet Footwell
A very common complaint. If you're lucky, the fault can be traced to the heating system, where its most likely caused by a leaking heater valve. In more serious cases, the heater matrix itself is damaged, and this usually shows up as coolant in both footwells rather than just the passenger side.
Of course, you need to determine that this is coolant; to do so, taste it. Coolant has a very sweet taste that is immediately identifiable. If it's not coolant, you've got water coming in from outside, and that can either be the rubber grommet where the Loom enters the cabin through the bulkhead, a blocked "elephant's trunk" in the engine bay or the worst scenario... Rust.
To check, pour a measured amount of fluid into the plastic grilles on the scuttle, and watch for fresh drips into the footwells. If you get them, you're going to have to remove the glovebox to investigate further, but be prepared for the dreaded tin-worm.
Another common cause of wet footwells is a leaking clutch cylinder. This hydraulic pump drives your clutch, and when its seals fail it will dump its fluid into your carpet. You'll get a corresponding softness in clutch feel, and may find it hard to shift gears. If this is the case, you need to change both your master and slave cylinders as a pair. Learn how to replace the clutch cylinders.
